SQL Query in VBScript
B
Brazil
I am trying to write a SQL query in vbs. I have been able to write a
script which queries a single table. My problem now is that I am not
sure how to structure the query for two tables. This is what I have
got so far:
Const adOpenStatic = 3
Const adLockOptimistic = 3
Const adUseClient = 3
Set objConnection = CreateObject("ADODB.Connection")
Set objRecordset = CreateObject("ADODB.Recordset")
objConnection.Open "DSN=Test;"
objRecordset.CursorLocation = adUseClient
objRecordset.Open "SELECT ComputerProperties.ComputerName,
ComputerProperties.ParentID, ComputerProperties.UserName,
ProductProperties.ParentID, ProductProperties.DatVer FROM
ComputerProperties, ProductProperties" , objConnection, adOpenStatic,
adLockOptimistic
strSearchCriteria = "ComputerProperties.ParentID =
ProductProperties.ParentID" objRecordSet.Find strSearchCriteria
If objRecordset.EOF Then
Wscript.Echo "Record cannot be found."
Else
wscript.echo objrecordset("ComputerProperties.ComputerName") & "
" & objrecordset("ProductProperties.DatVer")
End If
objRecordset.Close
objConnection.Close
When I run this script I get the following message:
"Arguments are of the wrong type, are out of acceptable range, or are
in conflict with one another"
Essentially, I am trying to run this SQL Query:
Select ComputerName, DatVer, UserName
From ComputerProperties, ProductProperties
where Computer.Properties.ParentID = ProductProperties.ParentID
and ProductProperties.ProductCode = 'Viruscan8600'
and DatVer < '5315'
Order By ComputerName
Does anyone know how I might be able to do this?
Many thanks,
Ben.
B
Brazil
thanks for your replies. I have changed my script as suggested by
Richard to the following:
strQuery = """" & """" & "SELECT ComputerName, DatVer, UserName" _
& " FROM ComputerProperties, ProductProperties" _
& " WHERE ComputerProperties.ParentID = ProductProperties.ParentID" _
& " and ProductProperties.ProductCode = " & "'" & "Viruscan8600" & "'"
_
& " and DatVer < " & "'" & "5315" & "'" _
& " Order By ComputerName" & """" & """"
wscript.echo strquery
objRecordset.Source = strQuery
objRecordset.Open
Else
End If
objRecordset.Close
objConnection.Close
When I run the script now I get the following error message:
The connection cannot be used to perform this operation. It is either
closed or invalid in this context. In my previous script I included
the following as part of the SQL query:
objConnection, adOpenStatic, adLockOptimistic
Do I need to include this somewhere?
Thanks,
Ben
K
Kathiravan Ilamparithi
VB Script to run the SQL Select query in Server.
i need to createa schedular which fetch the data from the table which is in server and it should be stored in to the .CSV format.
To create a batch File i need a VB Script to execute it.
Can anyone help me out in this?
Thanks in advance
EggHeadCafe - .NET Developer Portal of Choice
http://www.eggheadcafe.com/default.aspx?ref=ng
J
Joe Fawcett
Re: VB Script to run the SQL Select query in Server.
"Kathiravan Ilamparithi" wrote in message
news:200911715936ikathiravan@xxxxxx
> Hi,
> Thanks in advance
You can do this task in a number of ways (although I'm not sure why you need
a VBScript and a batch file):
(If it's SQL Server)
* A scheduled SQL Server job
* Scheduled OSQL script
http://msdn.microsoft.com/en-us/library/aa213090(SQL.80).aspx
(For general SQL databases)
* Use ADODB classes to retrieve data
* Use PowerShell and .NET
Joe Fawcett (MVP - XML)
http://joe.fawcett.name
