SQL Query in VBScript
M
mcolson
I am using the following code to perform a SQL query and return a
recordset I am getting the error "Arguments are of the wrong type,
are out of acceptable range, or are in conflict with one another"
This error occurs when I open the record set. What am I doing wrong?
Const adOpenStatic = 3
Const adLockOptimistic = 3
Const adUseClient = 3
Set objConnection = CreateObject("ADODB.Connection")
Set objRecordset = CreateObject("ADODB.Recordset")
objConnection.Open "DSN=ChartMES;"
objRecordset.CursorLocation = adUseClient
strQuery = "Use ChartMES " _
& "SELECT EmployeeID " _
& "FROM dbo.viewEmployeeTraining " _
& "WHERE TrainingName = 'Inner / Outer Mass Spec Training' " _
& "ORDER BY EmployeeID"
' Echo the query to the console to verify.
Wscript.Echo strQuery
'objRecordset.Source = strQuery
objRecordset.Open strQuery, objConnection, adOpenStatic,
adLockOpstimistic
If objRecordset.EOF Then
Wscript.Echo "Record cannot be found."
Else
Wscript.Echo "Record found."
End If
objRecordset.Close
objRecordset.Close
T
Tom Lavedas
> adLockOpstimistic
> Else
> End If
> objRecordset.Close
> objRecordset.Close
Is there a typo in this line ?...
adLockOpstimistic
I think you intended the last constant to be "adLockOptimistic" (no S
after the P).
_____________________
Tom Lavedas
M
mcolson
> > adLockOpstimistic
> > Else
> > End If
> > objRecordset.Close
> > objRecordset.Close
> adLockOpstimistic
> after the P).
> Tom Lavedas
ahh jeez. Thanks
