Start menu icons AND folders gone!
flatpro
2
The start menu icons and folders in all programs have all disapered.
i first noticed that all the folders were empty, so i restarted my laptop, to find everything but 2 programs firefox an utorrent gone?
all the programs are in all programs. Any ideas on why this happened?
thanks
A
Andre Da Costa[ActiveWin]
Can you do a System Restore to an earlier point in time before you started
experiencing this problem?
Start > type Command Prompt > right-click it and click "Run as
administrator".
Type in: SFC /SCANNOW and press your Enter key.
If that does not work, try repairing your system. Boot from your Windows
Vista DVD, select the System Repair Option > on the setup screen, select
'Repair Computer > Select your installation of Windows > select Startup
Repair option and follow instructions.
Andre
Blog: http://adacosta.spaces.live.com
My Vista Quickstart Guide:
http://adacosta.spaces.live.com/blog/cns!E8E5CC039D51E3DB!9709.entry
"flatpro" <flatpro.31yft0@xxxxxx-mx.forums.net> wrote in message
news:flatpro.31yft0@xxxxxx-mx.forums.net...
> Hi,
> thanks
> flatpro
L
lxg12345
When you hit the Windows key, any response?
A common but practical guess is that your computer has virus, check it out.
recommend Kaspersky. I hope that they are just "hidden" other than
"disappeared".
Before all of this ,try if you could do this: press "Ctrl + Alt + Del"at the
same time then choose Task Manager, check if there are any suspicious
process. You can simply press "Windows + R", then input "explorer.exe", see
if everything gets OK.
If not, try the last thing: restore you Vista, or reinstall it. It takes you
only about 20-30 minutes to install a new Vista. But you have to spend a lot
of time install and configure other programs.Remember to keep a backup of
you Operating System next time~
"flatpro" <flatpro.31yft0@xxxxxx-mx.forums.net> дÈëÏûÏ¢
> Hi,
> thanks
> flatpro
flatpro
2
hi,
thanks for the replys.
I have tried the scan now thing and it says its 99% complete but can not repair some corrupted files and points me to a 26mb log file.
I unfortunatly dont have a restor point set up
Im doint a virus scan now, i do however have a virus program AVG and a firewall.
i have looked in task man too but cant see anything i dont know, i normally keep as few things running to save batttery life
U
uvbogden
Take a look at Repair Vista Options.
http://www.vistax64.com/tutorials/101393-repair-vista-options-preferred-sequence.html
"flatpro" wrote:
> hi,
> firewall.
> flatpro
