Start-Transcript in Userprofile\My Documents
P
Personne
I'm trying to save all my Powershell Transcripts to a sub-folder of My
Documents like c:\Documents and Settings\myname\My Documents
\PowershellTranscripts\
I'm trying this
$p= "$env:UserProfile\My Documents\PowerShellTranscripts"
Start-Transaction -path $p
But I got this error message
Start-Transaction : A parameter cannot be found that matches parameter
name 'path'.
At line:1 char:24
+ Start-Transaction -path <<<< $p
+ CategoryInfo : InvalidArgument: (:) [Start-
Transaction], ParameterBindingException
+ FullyQualifiedErrorId :
NamedParameterNotFound,Microsoft.PowerShell.Commands.StartTransactionCommand
L
Larry__Weiss
One thing I see is that $p is a string that represents a folder, not a file.
You have to specify a particular file's name to write the transcript into.
Here's what I include in my profile.ps1 to automatically create a
transcript of my PowerShell sessions:
$global:TRANSCRIPT = "$env:UserProfile\My
Documents\WindowsPowerShell\Transcripts\PSLOG_{0:dd-MM-yyyy}.txt" -f
(Get-Date)
Start-Transcript -Append
I got the idea from this article:
http://blogs.microsoft.co.il/blogs/scriptfanatic/archive/2010/05/11/going-back-in-time.aspx
- Larry
On 5/21/2010 12:30 PM, Personne wrote:
> Hi,
> I'm trying this
> name 'path'.
> At line:1 char:24
> + Start-Transaction -path<<<< $p
P
Personne
I agree with you, but when I run just Start-transcript with no
parameter it does create a new file automatically like
PowerShell_transcript.20100521102901.txt
Seems the path option force me to manage the filename then
Thank
L
Larry__Weiss
I think you are correct.
From the help text for Start-Transcript
-Path <string>
Specifies a location for the transcript file. Enter a path
to a .txt file. Wildcards are not permitted.
If you do not specify a path, Start-Transcript uses the path
in the value of the $Transcript global variable. If you have
not created this variable, Start-Transcript stores the transcripts
in the $Home\My Documents directory as
\PowerShell_transcript.<time-stamp>.txt files.
If any of the directories in the path do not exist,
the command fails.
- Larry
> Thank
