Start up Programs
P
Pastor Mamie
How in the world can I get some of these programs oof my startup? I went
into change startup but it won't let me get some of this ridiculous stuff off
that is using almost a meg of ram! Please help!
K
Ken Blake, MVP
On Tue, 8 Jan 2008 11:10:01 -0800, Pastor Mamie <Pastor
On each program you don't want to start automatically, check its
Options to see if it has the choice not to start (make sure you
actually choose the option not to run it, not just a "don't show icon"
option). Many can easily and best be stopped that way. If that doesn't
work, run MSCONFIG from the Start | Run line, and on the Startup tab,
uncheck the programs you don't want to start automatically.
However, if I were you, I wouldn't do this just for the purpose of
running the minimum number of programs. Despite what many people tell
you, you should be concerned, not with how *many* of these programs
you run, but *which*. Some of them can hurt performance severely, but
others have no effect on performance.
Don't just stop programs from running willy-nilly. What you should do
is determine what each program is, what its value is to you, and what
the cost in performance is of its running all the time. You can get
more information about these at
http://castlecops.com/StartupList.html. If you can't find it there,
try google searches and ask about specifics here.
Once you have that information, you can make an intelligent informed
decision about what you want to keep and what you want to get rid of.
Ken Blake, Microsoft MVP Windows - Shell/User
Please Reply to the Newsgroup
