Start up time is very slow
C
Chad Z. Hower
Pentium D 960, dual core, 3.6 GHz+, RAID 0 striped high speed SATA
drives.
Its rare that something runs slow on this machine. But WCF initiation
takes 18 seconds. I can reboot XP quicker than that, in fact more than
once.
At first I thought it was an endpoint, which really worried me. I have
a need for multiple endpoints on a single machine (simulation). So I
added a second one - and to my delight the second one didnt take 18
seconds, it popped up right after the first.
Does anyone have any idea what takes 18 seconds and if I can speed it
up? Its really making debugging a chore. I dont have any code in my
init, its a simple console app derived from the standard WCF host
template.
The shell looks like this (Nothing useful to see, but to illustrate
what I mean better).
static void Start(string aURI) {
Console.WriteLine("Starting: " + aURI);
new AgentServiceHost(aURI);
Console.WriteLine(" OK");
static void Main(string[] args) {
Start("http://localhost:8080/x");
Start("http://localhost:8080/y");
Console.WriteLine("");
Console.WriteLine("All started");
Console.ReadLine();
So right away I see:
Starting http://localhost:8080/x
Then 18 seconds delay, then immediately all at once:
Ok
Starting http://localhost:8080/y
Ok
All started
"Programming is an art form that fights back"
http://www.KudzuWorld.com/
Need a professoinal technical speaker at your event? See www.woo-hoo.net
C
Chad Z. Hower
> Ok
> Ok
> All started
Now that I have each one running in its own AppDomain, its 18 seconds
for each one. :( Start up time during debugging is horrible.
C
Chad Z. Hower
Actually its not 18 seconds each one, but more like 20 for first, 10
for second and so on.
I put them in a threadpool so that they would all start simulteaneously
and hopefully thus when I started 10 or so, it would take 20 seconds
and not 110. But even threadpool + app domains does not help. It still
takes just as long. :(
C
Chad Z. Hower
C
Chad Z. Hower
> WCF server startup slow on W2K3 in VM
> http://blogs.thinktecture.com/ingo/archive/2006/09/04/414684.aspx
> I'm on XP and not even part of a domain, but maybe?
Bugger all. :( Thats what it is. This machine has two ethernet + wifi +
several virtual adaptors. WCF is only using one, but that is exactly
what is taking so long.
Anyone have any work arounds? I'm on XP Pro, cant make it a domain
controller and I really cant drop it from the network either.
A
Arkady Frenkel
Didn't you tried to disable adapters before ?
Arkady
"Chad Z. Hower" <chad-ng@hower.org> wrote in message
news:eqJNBD74GHA.512@TK2MSFTNGP06.phx.gbl...
C
Chad Z. Hower
I cant - I need this machine to be on the internet. Besides I did a TCP
spy and its only using one adaptor, the main one.
Need a professional technical speaker at your event? See www.woo-hoo.net
A
Arkady Frenkel
#8
Hi, Chad!
news:uohq6d45GHA.4116@TK2MSFTNGP03.phx.gbl...
That proposition for tests only.
Sure, only one used due to route table ( IP of route with less metric - you
can check which with "route print" command in dos box routing ). For me it
always take few seconds ( up to 3-5 ) but not 18 ( but I'm in domain ) both
on IIS or as selfhost. Did you tried to add to domain ( temporarily ) to see
the difference ?
Arkady
