Startup Subst both normal and administrator
M
MartinDC
I have mapped a drive on my main Vista machine for all my documents
etc. N:.
With XP it was also possible to map to the local machine to make sure
that N: on all machines was the same. But with Vista "net use" does
not work locally so I have to use "subst". Trouble is that if I want
to subst the drive to both normal and administrator users, then I have
to subst twice. But how can I subst from the startup folder? (And
then for both levels.)
Martin
A
Andrew Rossmann
[This followup was posted to
microsoft.public.windows.vista.networking_sharing and a copy was sent to
the cited author.]
In article <32f57832-c873-46d4-891b-55b9974e7eb1
@n20g2000hsh.googlegroups.com>, martin@xxxxxx says...
> etc. N:.
Huh? 'NET USE \\thiscomputer\share' does work with Vista. I currently
have an E: that is just a shared subdir of C: (done due to some old
program I copied from another computer). Make certain the Server service
is running, and that file sharing is enabled in Network settings. You
may also need to tweak firewall settings.
To use SUBST, you could create a simple text file containting the
command with a .CMD or .BAT extension, and put it under:
\Users\All Users\Microsoft\Windows\Start Menu\Program\Startup
To be safe, try making it look like this:
SUBST N: /D
SUBST N: c:\whatever\whatever
If there is a no_junk in my address, please REMOVE it before replying!
All junk mail senders will be prosecuted to the fullest extent of the
law!!
http://home.att.net/~andyross
I want to do the same thing. I used to have a network drive mapped to U:, but I have moved all that locally.
Some programs (one in particular, iTunes) don't do well if you move their file paths around. So now I want to have a virtual u: mapped to a location on C:.
I could use NET USE. However, 1) this means I now have to maintain share permissions as well as local permissions (although this is not a big deal) and 2) I am not sure if this is a waste of resources- is the system now routing all this traffic through the network layer when it doesn't have to?
So I want to use "subst". The problem on Vista/W7 is that this is a per-user command, and it will not show up in the explorer unless it has been run twice- as both the current user and as Administrator.
So the question becomes: How do you run the command (either in a batch file or through some registry entry) as both the user and an Administrator at login?
