StdOut.ReadAll blocking?
L
lucadentella
Hello!
I'm working on a script using the WshShell.Exec() method.
To avoid buffer overflow problem (if I read the whole StdOut at the
end of the execution, sometimes my script hangs) I found a suggestion
on the "Hey, Scripting Guy!" MS blog: use a StdOut.ReadAll inside the
waiting loop.
But please notice these two examples:
-- Ex1, without ReadAll --
Dim elapsedSecs
elapsedSecs = 0
Dim quit
quit = False
Dim objShell
Set objShell = CreateObject("WScript.Shell")
Dim objCmd
Set objCmd = objShell.Exec("ping 10.113.203.200")
Do While quit = False
If objCmd.Status = 1 Then
quit = True
Else
WScript.Sleep 100
elapsedSecs = elapsedSecs + 0.1
End If
Loop
WScript.Echo "Elapsed seconds: " & elapsedSecs
-- output: "Elapsed seconds: 2,8"
-- Ex2, with ReadAll --
Dim elapsedSecs
elapsedSecs = 0
Dim quit
quit = False
Dim objShell
Dim objCmd
If Not objCmd.StdOut.AtEndOfStream Then
outBuffer = outBuffer & objCmd.StdOut.ReadAll
End If
quit = True
Else
WScript.Sleep 100
End If
Loop
-- output: "Elapsed seconds: 0"
It seems ReadAll is blocking my loop until the objCmd exits... why?
thanks!
O
Old Pedant
ReadAll does a *synchronous* read.
It really and truly means "read all output produced by writes to StdOut by
the given object."
So of course it has to wait until the logical EOF is received from the thing
it is reading from. And that doesn't happen with PING until the ping object
is done.
How about trying ReadLine???
startTime = Timer( )
quit = False
outBuffer = ""
Do
outBuffer = outBuffer & objCmd.StdOut.ReadLine
End If
If objCmd.Status = 1 Then Exit Do
If timer( ) > startTime + 20 Then
outBuffer = outBuffer & vbNewLine & "*** TIMED OUT ***"
Exit Do
End If
WScript.Sleep 100
Loop
endTime = Timer( )
WScript.Echo "Elapsed seconds: " & (endTime - startTime)
WScript.Echo outBuffer
L
lucadentella
Hello!
Thanks! Your solution resolved my problem!
> the given object."
> is done.
> quit = False
> outBuffer = ""
> Do
>     End If
>          Exit Do
>     End If
>     WScript.Sleep 100
> Loop
> endTime = Timer( )
