Steppable Pipelines in Powershell 2.0 CTP
T
Tao Ma
I notice this new feature:
Steppable Pipelines
This feature allows turning a script-block into a steppable pipeline and
then controlling the sequence of activities by individually calling Begin(),
Process() and End() on the pipeline.
I dont know what is the meaning of this. Who can offer an example for me.
Thanks in advance,
Best wishes.
M
Marco Shaw [MVP]
> Steppable Pipelines
> Begin(), Process() and End() on the pipeline.
Example:
PSH> function step {
>> begin{write-host "Starting..."}
>> process{$_.name}
>> end{write-host "Ending..."}
PS> get-childitem . *.ps1|step
Starting...
1.ps1
.... <--removed
test.ps1
test1.ps1
.... <--removed
Ending...
In the begin() and end() part, you're not actually doing anything with
the objects coming in.
Marco
Microsoft MVP - Windows PowerShell
http://www.microsoft.com/mvp
PowerGadgets MVP
http://www.powergadgets.com/mvp
Blog:
http://marcoshaw.blogspot.com
M
Marco Shaw [MVP]
> Example:
> process{$_.name}
> Starting...
> 1.ps1
> ... <--removed
> test.ps1
> test1.ps1
> ... <--removed
> Ending...
OK, this is the basic concept behind a steppable pipeline, but isn't
really the new feature added in the v2 CTP.
I use a function above to demonstrate, but v1 functions can also do the
above.
This may be more of an addition to the new scriptcmdlets feature, the
more I think about this.
I can't come up with a practical example right now, but will think about it.
Marco
PowerGadgets MVP
Blog:
M
Marco Shaw [MVP]
This is from the v2 CTP readme below. Another example can be found in
Sapien's PowerShell TFM *3rd edition* ebook:
Get-childitem ScriptCmdlet that only shows containers if ¨Ccontainersonly
parameter is passed.
cmdlet Get-ChildItem `
param(
[Position(0)] `
[ValueFromPipeline] `
[ValueFromPipelineByPropertyName] `
[System.String[]] `
$Path,
[switch] $ContainersOnly
begin
$wrappedCmdlet = get-command -type cmdlet Get-ChildItem
[void] $CommandLineParameters.Remove("ContainersOnly")
if ($containersonly)
$sb = {& $wrappedCmdlet @CommandLineParameters | `
where {$_.PSIsContainer} }
else
$sb = { & $wrappedCmdlet @CommandLineParameters }
$sp = $sb.GetSteppablePipeline()
$sp.Begin($cmdlet)
process { $sp.Process($_) }
end { $sp.End() }
T
TaoMa
Thank you for your help. It's really hard to figure out this new features.
I wrote a wired code like this:
1..3 | &{ BEGIN {"head"} PROCESS{$_} END{"tail"} }
Latterly, I found it can be processed in V1. It seems no one cares this
feature at all. Maybe this is not a big deal :)
Best wishes
"Marco Shaw [MVP]" <[email protected]_NO_SPAM_gmail.com> дÈëÓʼþ
news:[email protected]
> > Example:
> > process{$_.name}
> > Starting...
> > 1.ps1
> > ... <--removed
> > test.ps1
> > test1.ps1
> > ... <--removed
> > Ending...
> above.
it.
> Marco
> PowerGadgets MVP
> Blog:
M
Maximilian Hänel
Hi TaoMa,
I think the key point is that you can convert an arbitry script block to
a steppable pipline "object". With this kind of object, you can the call
the begin, process and end method _yourself_ whereas with an ordinary
scriptblock you can only call the "whole thing" at once.
Marco already posted an example:
now you can call begin, process and end on the $sp variable - the
steppable pipeline.
$sp.Begin()
$sp.Process('bla') # call process as often as you want - step by step!
$sp.Process('foo')
$sp.End() #end of story..
Without converting the scriptblock to a steppable pipeline you must call
it as "one big thing":
.. $sp # run the whole script/pipeline/whatever
This is only a guess, however...
cu
Max
T
TaoMa
I'm too careless to read Marco Shaw's post. Thank you for your help.
It's all my fault.
Best wishes!
"Maximilian Hänel" <[email protected]> ????
news:%[email protected]
> Hi TaoMa,
> steppable pipeline.
> $sp.Begin()
> $sp.Process('foo')
> cu
> Max
