STOP message at startup 0x00000024 (0x00190203, 0x841EA348, ...
J
Jared
STOP: 0x00000024 (0x00190203, 0x841EA348, 0xC0000102, 0x00000000)
Heya. I have a Dell Dimmension PC. (Dell error code 0F00:1378 shows up
when I use the Dell diagnostic, if that helps anything). I had recently had
spyware/adware issues, but as far as I could tell I had cleared it out
completely.
Anyways, my computer froze up last night and I had to forcefully turn it off
(by hitting the power button and holding it for 6 seconds). When I went to
turn it back on, it looks as if its going to open fine, but after the loading
screen is up for a few seconds, I get a Blue Screen with that STOP message.
It recommends disabling/uninstalling my antivirus programs/firewall to try
to fix it, but as Windows will not even open in Safe Mode, I do not see how
that is possible.
If you have any ideas, either reply here or at Jburrrow777[at]aol[dot]com or
soldier.in.christ[at]gmail[dot]
D
Dieselhog
Hi Jared,
I have the similar problem with the same symptom (But the second error code
is 0x86771A98). Did you ever get a response or got it sorted by yourself.
Any hint would be much appreciated.
/Dieselhog
> completely.
> that is possible.
B
bobdum
RE: STOP message at startup 0x00000024 (0x00190203, 0x841EA348, ..
Hi guys,
I think you can find a revelative answer in the microsoft kb228888 at:
http://support.microsoft.com/kb/228888
Hope it will help you.
"Dieselhog" wrote:
> Hi Jared,
> /Dieselhog
> > completely.
> > that is possible.
N
niteman69
The Stop message I get are first 0x0000008e then 0x00000024 I get them while
in IE7 Dell was of no help at all told me to call Microsoft. But they want
60.00 to help anyone thet can help me with this I would be thankfull.
"bobdum" wrote:
> Hi guys,
> "Dieselhog" wrote:
> > Hi Jared,
> > /Dieselhog
> > > completely.
> > > that is possible.
