Strange Icon on Taskbar - black box with 9
I am not sure it has been always there or not but I noticed a strange looking black box with a number 9 on my taskbar (I have Windows Vista Home version).
I clicked on it but nothing happens. I went into the Taskbar property and it shows the blackbox with the number 9 in it but it has no info.
Has anyone seen that before?
How can I find out what kind of program this is?
Any suggestion?
I want to stop this program but I have no idea what this program is.
Thanks.
how do you make the screenshot?
It's a blackbox and number 9 is written in white.
What is a speedfan cpu monitor?
Also, when I click on it, nothing happens. If this is a legit program, why would nothing happen? I am very very curious. Could this be some sort of spyware?
lil domii
Seven Guru + GFX
Power User
I am having the same issue but it's on a Win 7 64 bit system.
If I right click on it, it does nothing, double click does nothing.
I sure don't remember it being there last week.
richc46
Staff member
Do an antivirus check and download and use malwarebytes to check for malware. If it is still there, post your problem in a new thread to avoid confusion. You will, then receive our full attention.
