Stubborn Wireless Connectivity Problem
R
Rich
I hope someone can help me with an ongoing, intermittent problem connecting
wirelessly to routers, Hotspots, etc. I have a Gateway laptop running Vista
Home Basic with an internal b/g wireless card.
I have a wireless network at home to which I've never had problems
connecting. However, while attempting to access the internet via wireless
routers at Hotspots and at friends' houses, I continuously experience
problems establishing the initial connection, even while using the correct
network key (where necessary) and while other PCs are connected to the router
at the same moments. At other times, I'm able to connect to other wireless
routers effortlessly.
I've tried everything: disabling the Windows and McAfee firewalls, checking
the power setting on the adapter, pulling the oldest and latest drivers for
the wireless card, placing the laptop directly next to the router for the
best signal, unchecking IPv6 in the wireless properties, etc. I've run the
network diagnostics each time, which fails to give me a solution. The most
common error message: Windows did not receive a response from the router.
Any suggestions?
I don't want to post a lot of junk here, but here are a couple entries from
the system logs at the time the connectivity problem was occurring (I was
trying to connect to ActionMutanteNet):
Provider Name="Microsoft-Windows-Diagnostics-Networking"
Guid="{36c23e18-0e66-11d9-bbeb-505054503030}" />
<EventID>6100</EventID>
<Version>0</Version>
<Level>4</Level>
<Task>12</Task>
<Opcode>0</Opcode>
<Keywords>0x4000000000000002</Keywords>
<TimeCreated SystemTime="2007-11-19T13:53:24.657Z" />
<EventRecordID>5760</EventRecordID>
<Correlation ActivityID="{D8FEEABF-233B-442C-9E4A-C44CA2E7ADDC}" />
<Execution ProcessID="3420" ThreadID="3524" />
<Channel>System</Channel>
<Computer>Rich-PC</Computer>
<Security UserID="S-1-5-19" />
</System>
- <EventData>
<Data Name="HelperClassName">AutoConfig Helper Class</Data>
<Data Name="EventDescription">Wireless Diagnostic Informational Event
Information for connection being diagnosed Interface GUID:
a82d84a1-ef11-494c-b7d9-64f35d75799f Interface name: Realtek 8185 Extensible
802.11b/g Wireless Device Interface type: Native WiFi Profile: Discovery
connection SSID: ActionMutanteNet SSID length: 16 Connection mode: Infra
Security: Yes Connect even if network is not broadcasting: No Connection
incident diagnosed Auto Configuration ID: 1 Connection ID: 2 Connection
status summary Connection started at: 2007-11-19 08:52:11-670 Profile match:
Success Pre-Association: Success Association: Fail Security and
Authentication: Not started List of visible access point(s): 9 item(s) total,
9 item(s) displayed BSSID BSS Type PHY Signal(dB) Chnl/freq SSID
00-1B-2F-5B-7E-96 Infra g -70 11 ActionMutanteNet 00-16-E3-5F-D3-50 Infra g
-80 11 ALICE-WLAN 00-1C-10-09-36-36 Infra g -90 11 801901 00-13-49-F3-7B-7F
Infra g -88 6 DSLWLANModem2005kX9 00-12-A9-C4-3D-5E Infra g -92 11 BinDafür
00-1A-4F-DD-FB-B3 Infra g -88 11 WLAN-001A4FDDFBB3 00-1A-4F-97-DB-4C Infra g
-95 11 WLAN-001A4F97DB4C 00-90-4C-7E-00-10 Infra g -90 11 NETGEAR
00-19-E3-E3-6F-5D Infra g -90 1 Das Tor Connection History Information for
Auto Configuration ID 2 List of visible networks: 9 item(s) total, 9 item(s)
displayed BSS Type PHY Security Signal(RSSI) Compatible SSID
Infra g Yes 49 Yes ActionMutanteNet Infra g Yes 30 Yes ALICE-WLAN Infra g Yes
9 Yes 801901 Infra g Yes 13 Yes DSLWLANModem2005kX9 Infra g Yes 9 Yes
BinDafür Infra g Yes 13 Yes WLAN-001A4FDDFBB3 Infra g Yes 7 Yes
WLAN-001A4F97DB4C Infra g Yes 9 Yes NETGEAR Infra g Yes 10 Yes Das Tor List
of preferred networks: 1 item(s) Profile: Castalia SSID: Castalia SSID
length: 8 Connection mode: Infra Security: Yes Set by group policy: No
Connect even if network is not broadcasting: No Connectable: No Reason:
0x00028001 Information for Connection ID 3 Connection started at: 2007-11-19
08:53:04-120 Auto Configuration ID: 2 Profile: Discovery connection SSID:
ActionMutanteNet SSID length: 16 Connection mode: Infra Security: Yes
Pre-Association and Association Connectivity settings provided by hardware
manufacturer (IHV): No Security settings provided by hardware manufacturer
(IHV): No Profile matches network requirements: Success Pre-association
status: Fail 0x00000000 Association status: Fail 0x00000000 Association
reason code: 0x00000000 Information for Auto Configuration ID 1 List of
visible networks: 9 item(s) total, 9 item(s) displayed BSS Type PHY Security
Infra g Yes 50 Yes ActionMutanteNet Infra g Yes 33 Yes ALICE-WLAN Infra g Yes
4 Yes 801901 Infra g Yes 10 Yes DSLWLANModem2005kX9 Infra g Yes 7 Yes
BinDafür Infra g Yes 7 Yes WLAN-001A4FDDFBB3 Infra g Yes 6 Yes
WLAN-001A4F97DB4C Infra g Yes 4 Yes NETGEAR Infra g Yes 7 Yes Das Tor List of
preferred networks: 1 item(s) Profile: Castalia SSID: Castalia SSID length: 8
Connection mode: Infra Security: Yes Set by group policy: No Connect even if
network is not broadcasting: No Connectable: No Reason: 0x00028001
Information for Connection ID 2 Connection started at: 2007-11-19
08:52:11-670 Auto Configuration ID: 1 Profile: Discovery connection SSID:
status: Success Association status: Fail 0x00038002 Association reason code:
0x00010006 Information for Connection ID 1 Connection started at: 2007-11-19
08:49:53-561 Auto Configuration ID: 1 Profile: Discovery connection SSID:
status: Success Association status: Success Last AP: 00-1b-2f-5b-7e-96
Security and Authentication Configured security type: WPA2-PSK Configured
encryption type: CCMP(AES) 802.1X protocol: No Key exchange initiated: Yes
Unicast key received: No Multicast key received: No Number of security
packets received: 0 Number of security packets sent: 0 Security attempt
status: Fail 0x00048014</Data>
<Data Name="EventVerbosity">0</Data>
</EventData>
</Event>
="EventDescription">Wireless Diagnostic Helper Class Event For complete
information about this session see the Wireless Diagnostic Informational
Event. Helper Class: Native WiFi MSM Initialize status: Success Information
Security: Yes Connect even if network is not broadcasting: No Result of
diagnosis: Problem found Root cause: Windows cannot connect to
"ActionMutanteNet" Wireless association failed due to an unknown reason.
Detailed root cause: 802.11 connection failed due to status code 1:
unspecified failure Repair option: Try connecting to "ActionMutanteNet" again
If the problem continues, contact your network administrator or hardware
manufacturer for further assistance.</Data>
J
Jrz
> Any suggestions?
how about disabling autotuning via NETSH?
the new TCP/IP stack seems to have problems with certain routers
have you noticed that Vista is the common denominator? is a good spot
always good, and a bad spot always bad?
R
Rich
No common denominators. I was told in one situation that other people with
Vista (including the guy's roommate) have never had a problem there. And in
another situation, I was in a Starbucks with the same laptop a few months
earlier and had logged right on.
J
Jrz
Rich wrote:
http://www.scroogle.org/cgi-bin/nbbw.cgi?Gw=vista+autotuning
it is easy to try, good luck:
C:\>netsh interface tcp set global autotuninglevel=disabled
Ok.
C:\>netsh interface tcp show global
Querying active state...
TCP Global Parameters
Receive-Side Scaling State : enabled
Chimney Offload State : enabled
Receive Window Auto-Tuning Level : disabled
Add-On Congestion Control Provider : none
ECN Capability : disabled
RFC 1323 Timestamps : disabled
E
Ed Allan
Base Filtering Engine
Various people (including myself) have asked for guidance because their
laptops with Vista frequently do NOT connect at public hotspots, e.g.,
coffeeshops.
Someone mentioned that disabling the "Base Filtering Engine" helped them
greatly.
1. What is the Base Filtering Engine?
2. How does one disable it?
3. SHOULD one disable it?
Thanks in advance
J
Jrz
Re: Base Filtering Engine
> coffeeshops.
> greatly.
- use Windows Key + r to bring up the Run dialog
- type in services.msc then hit Enter
- select the BFE service and then click Stop
you can instantly start it up again. Let us know if it helps.
also you can try:
netsh interface tcp set global disable disable disable
netsh interface tcp set global enable enable normal
will reverse what you just did
> Thanks in advance
