Sudden Blank Screen on Laptop
Hello, i have a basic Toshiba laptop "new" with the basic Windows Vista on
it. For some reason every so often, about twice a day, the screen will
suddenly go blank. I can still hear music that im playing or whatever, but
the screen is blank and the only way to clear it is to manually push the
power button to restart the computer. All i use the laptop for is itunes and
surfing the web, checking emails. it has never been dropped. its sits on a
desk and doesnt move. if anyone could offer any adivce that would be greatly
appreciated.
S
Spirit
Sounds like it going into Sleep Mode or Hibernate.
Check your model's manual for how to Resume from Sleep and/or Hibernate
http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_home.jsp
BTW pressing the Power Button on most models WAKES it from Hibernation
which is what you are doing. If you have closed the Lid and it goes into
Hibernation
then opening the Lid "usually" wakes it up from Hibernation.
"jcc" <jcc@xxxxxx> wrote in message
news:000E2370-11F3-426E-98C9-F591FC74F5C1@xxxxxx
> and
> greatly
> appreciated.
C
crazylynn
jcc - I also have a one month old Toshiba A210 laptop and am having exactly
the same problem. I intend to go back to the dealer to find out what's going
on. This is very annoying/disappointing.
crazylynn
> appreciated.
D
Dwarf
Hi jcc,
This has something to do with your power settings. To check this, click on
the start orb and then select 'Control Panel'. Select 'System and
Maintenance' and 'Power Options'. On the left hand side of the screen is a
list of tasks. One of these tasks is 'Choose when to turn off the display'.
Select that option. In the scroll box next to 'Turn off the display' select
whatever you wish. If you want the display to remain on then select 'Never'.
Click on 'Save changes.This saves the changes and closes this dialogue page.
Close all other windows that you opened in this procedure. Note that if you
do that your operational time on battery power will be greatly reduced as the
display consumes quite a bit of energy.
Dwarf
> appreciated.
Hey Guys,
Ive been having problems identical to the ones described above. I also have a Toshiba Satellite with Vista that I just purchased yesterday. Its been doin the sudden blank screen thing and the only the way to turn it back on is to totally turn off the computer and restart it. I talked to a guy from GeekSquad and I think I got it fixed. Try this and tell me if it works for you!
Control Panel(Classic View) > User Accounts > Turn user acount control on or off > then uncheck that box so that it is turned off.
It appears to have worked for me, I've been listening to music and watching videos for the past hour as a test and it hasnt failed me yet!
S
sis1car
> appreciated.
R
rizman
Toshiba P205D-S7438
Vista Home Premium
Like many of you, the computer was sleeping (black screen, must power
back on) after about 5 minutes on AC power. Much longer on battery
power.
Toshiba tech support was absolutely clueless. The BIOS upgrade (1.4)
had no effect whatsoever.
I hesitate to claim I "fixed" it, but after going to the power settings
and specifying for the computer never to sleep, it has been running for
50 minutes so far on AC.
I'll keep my fingers crossed and hope this helps you all end this nasty
experience.
rizman
Posted via http://www.vistaheads.com
K
Klindt
#8
I found the problem on my dell Inspiron with an ATI radeon x1150 a new
driver for this card were the solution !!
"rizman" <rizman.39bfce@xxxxxx-mx.forums.vistaheads.com> skrev i meddelelsen
news:rizman.39bfce@xxxxxx-mx.forums.vistaheads.com...
> Toshiba P205D-S7438
> Vista Home Premium
> power.
> experience.
> rizman
R
rizman
#9
I'm glad you got a fix. I'm no computer expert, just a heavy user, and
I wonder if it's common for a problem to have so many different fixes?
The weird thing for me was that the computer worked just fine until SP1
was installed. I'm not blaming it, but it seems that what started to
happen after that was Vista disregarded the values that were entered for
the machine sleeping. Whether you specified 25 minutes or 5000 minutes,
the machine slept after 5 minutes on AC, and, what's even less useful,
it slept when the machine was in use, not sitting idle.
Hopefully, the genuine experts on Vista will investigate this. The
other troubling aspect has Toshiba advertising a BIOS fix that doesn't
address the issue.
rizman
#10
I used the link spirit gave to check out my problem (I knew it had nothing to do with the settings for Sleep and/or Hibernate mode) and found that it's all about the setting of your desktop saver being in "blank"... Toshiba Support - Content Details
It worked for me... Hope your problem will be solved as well... :)
