suggest a mid-range card
dv29
2
hi i have the following config:
HP VP17 17" LCD max res 1280*1024-60Hz
intel core2duo E4500 2.2Ghz
mobo:Asus P5LP-LE
chipset intel 945g
1 pci express*16 slot
i wanted to know if xfx geforce 9600gt 512mb is compatible.
also my monitor supports only vga but the card needs dvi.can u suggest a vga card
also how much power supply is required.thanks in advance
johngalt
Antidisestablishmentarian
3,912
Location
3rd Rock
Hi, dv29, and welcome to the forums.
The only compatibility issues you *should* run into is if your motherboard supports PCI-e 2.0 or not.
As for PSU requirements, visit eXtreme Power Supply Calculator Lite v2.5 and calculate it yourself...but be-warned, this will require some intimate knowledge of your computer components.
  • Show second system?
    Yes
    Operating System
    Windows 10 Insider Preview current build
    The Beast Model V
    eVGA X58 Classified3
    3 * 4GB Mushkin Enhanced Redline CL7 DDR3 1600 MHz (PC3-12800)
    eVGA GTX 970 + eVGA GTX 560 Ti 448 Core Classified (PhysX)
    Realtek HD Audio (onboard)
    2 * Lenovo LT2323pwA
    2 * 1920 x 1080
    SanDisk Ultra SDSSDHII-960G-G25 SATA III SSD (System)
    Crucial MX100 CT256MX100SSD1 SATA III SSD (User Tree)
    2 * Seagate Barracuda 7200.12 ST31000528AS SATA II
    Seagate ST1500DL001 7200 RPM SATA II
    Intel SSDSA2M080G2GC SATA II SSD
    ThermalTake BlackWidow 850W
    ThermalTake Level 10 GT
    Corsair H100 (CPU) + Air (2 * 210 mm + 3 * 120mm fans)
    Logitech MX Master
    Logitech G15 (gen 2)
    300+ Mbps downstream / 30+ Mbps upstream
    Windows 10 Insider Preview (current)
    Dell Inspiron 3521
    Intel(R) Celeron(R) CPU 1007U @ 1.50GHz
    Dell
    Intel(R) HD Graphics
    Intel(R) Display Audio | Realtek Audio
    Inspiron 15"
    1680 * 1050
    INTEL SSDSC2CW180A
    Dell
    Dell
    Dell
    Logitech MX Master | Synaptics TouchPad
    Dell
    300+ Mbps downstream | 30+ Mbps upstream
skunksmash
im coming for cake
2,254
Location
norfolk
Hi dv29..... & welcome
according to THIS i see no reason it wont work, but you already know your generic PSU probably wont cut it, does the existing PSU have a dedicated 6pin plug for PCI-e..??
a 9600 is hardly a power hungry card, depending on the amount of peripherals you have THIS will run the 9600 all day long & its a solid power unit.
just use a DVI to VGA dongle found HERE
:)SK
    ME.....
    Q9450 @ 3.6ghz
    P5K PREMIUM
    8GB 1066mhz buffalo firestix
    HD 5970
    20'' syncmaster
    XCILIO 850w
    unknown ATX
    Arctic cooler pro 775
    logitech cordless optical
    logitech EX110
    2mb
stormy13
633
If you don't want to have to worry about the power supply, a HD 4670 would be a very good choice. Performs for the most part between the HD 3850 and the HD 3870, and not too far off the 9600 GT, and does not require the extra power connector.
    Me
    Athlon x2 7750 BE
    Asus M4A78 Pro
    2x2gb Kingston
    Sapphire HD 4830
    X-Fi Xtreme Music
    Acer P221w and Acer 1916w
    1680x1050 and 1440x900
    Antec Earthwatts 500W
    Antec Sonata III
    Logitech G5 v2
    Logitech Wave
well if you don't mind somewhat cheap........ a HD3450 is not to bad :) its what i use and it ran COD4 ok
    AMD Athlon X2 5000+ @ 2.6Ghz
    Acer Micro-ATX Motherboard
    ATI HD3870 with 512mb GDDR4
    Realtek HD 7.1 Onboard Sound
    22" Acer X223 Widescreen
    1680 X 1050
    500gb Seagate SATA II
    ULTRA X3 600 Watt Modular
    Microsoft Sidewinder X5
    Microsoft Sidewinder X6
    6 Mbs Down 1 Mbs Up
    AVerMedia 1500MCE TV Tuner
