Suggested size of 2008 Premium C: drive with VM?
I
I have done the 'homework' and understand that 80GB is a reasonable starting
point for the C: drive for SBS 2008.
If the C; drive also holds a VM structure and child SBS2008 and the SQL
element is 80Gb still sufficient (for now).
I do recognise that historically the program files have grown and goodness
only knows what size will be necessary if 5 year's time, but that is a risk
we are all taking, I guess!
IanB
L
Lanwench [MVP - Exchange]
> starting point for the C: drive for SBS 2008.
> SQL element is 80Gb still sufficient (for now).
Nope, I wouldn't say so! And I'm presuming you mean you're going to be
using VMWare to host SBS, SQL, etc - not that SBS2008 itself will be running
VMWare and hosting VMs.
> goodness only knows what size will be necessary if 5 year's time, but
> that is a risk we are all taking, I guess!
Hence you should overestimate. :)
I
Come off the fence LW; suggest a number!
IanB
> > IanB
C
Charlie Russel - MVP
FWIW, I chose to install on a fixed size VHD of 120 GB for my SBS 2k8 C:
drive. With most things moved off of C: using the wizards, I expect that to
be sufficient for a while.
Charlie.
http:/msmvps.com/blogs/xperts64
"IanB" <IanB@newsgroup> wrote in message
news:F443A761-6D09-4DCD-A3F1-DBA86CC06FC9@newsgroup
> IanB
>> running
>> > IanB
L
> IanB
LOL. I'm not trying to be evasive. I just think I'd want a lot more -
depends on whether you're using ESX, and whether your SQL box will require a
lot of space. I would agree with Charlie's 120GB but that's just a guess on
my part./
>> be using VMWare to host SBS, SQL, etc - not that SBS2008 itself will
>> be running VMWare and hosting VMs.
>>> but that is a risk we are all taking, I guess!
>>> IanB
