Suggestion: Implicit invocation should work with non-Filesystem items
  • Thread starter Alex K. Angelopoulos [MVP]
  • Start date
A
https://connect.microsoft.com/feedback/ViewFeedback.aspx?FeedbackID=128556&SiteID=99
At present, you can only invoke items directly by path if they are accessed
via a FileSystem-provided PSDrive.
Extending implicit invocation to other providers - and giving guidance for
it - will give us simple, intuitive methods to access specific functionality
that also allows us to do things we cannot explicitly do at present. Here's
a rough outline of how the concept would work.
When a provider is implemented, guidance should suggest supporting
invocation as well. Invocation would 'run' the item in a way that is
sensible, logical, and useful. For existing providers (and some theoretical
ones) it might make sense to have the following happen.
Function PSProvider:
Execute the function. You could then explicitly specify function:\more and
be guaranteed to get function:\more or - if it had been removed - nothing.
This would be exactly analogous to explicitly specifying a commandline
executable by path.
Alias PSProvider:
If alias:\gcm is specified, behavior will be identical to specifying just
gcm. I'm not sure about the usefulness of this given that aliases are always
resolved first; it would just be consistent.
Theoretical - Cmdlet PSProvider and Script PSProvider:
If providers for seeing scripts and cmdlets analogously to functions are
ever implemented, they should also behave the same way. One could then, for
example, get identical results from each of the following:
cmdlet:\Get-Command cmdlet:\Get-Command -Usage
cmdlet:\Get-Command Get-Command -Usage
Variable and Environment PSProviders:
Possibly behaves as Get-Item?
This should simply return the value of the specific variable, precisely as
direct use of the variable does. I'm not sure what the use would be for this
specifically, although it would be consistent and intuitive.
We already have something roughly similar in that items can be found in
these providers like this:
$env:path returns the path
$variable:pshome returns the pshome path
By extending invocation, the following would be equivalent:
env:\path would do the same thing as $env:path
variable:\pshome would do the same thing as $variable:pshome
Certificate and Registry PSProviders
Specifying a registry or certificate item by path would probably be best
treated as meaning to return the specific certificate or key.
D
dreeschkind
RE: Suggestion: Implicit invocation should work with non-Filesystem it
I think this has already been suggested:
https://connect.microsoft.com/feedback/ViewFeedback.aspx?FeedbackID=77319&SiteID=99
greetings
dreeschkind
> executable by path.
> Alias PSProvider:
A
Re: Suggestion: Implicit invocation should work with non-Filesystem it
Yes, and I just rated it a 5. :)
"dreeschkind" <dreeschkind@discussions.microsoft.com> wrote in message
news:882120EF-C9A5-4CC3-AF1E-88FBFE24DE9C@microsoft.com...
> greetings
> dreeschkind
>> accessed
>> for
>> functionality
>> Here's
>> theoretical
>> and
>> nothing.
>> executable by path.
>> Alias PSProvider:
>> always
>> for
>> as
>> this
