suppressing confirmation prompt
P
Peter Lawton
I'm having problems running an Exchange shell script automatically because I
can't suppress the confirmation prompt. I've tried asking in an exchange
group but nobody there could help.
The command I'm trying to run is:-
get-mailbox | set-mailbox -Confirm:$False -ManagedFolderMailboxPolicy
"Default Policy"
But I get the prompt:-
Confirm
When assigning a managed folder mailbox policy with managed custom folders
to
the mailbox "domain/Users/username", Outlook clients older than
Outlook 2007 do not have all available client features and clients older
than
Outlook 2003 SP2 are not supported. You may use the "Set-CASMailbox" task to
enable client version blocking. Are you sure you want to assign a managed
folder mailbox policy to this mailbox?
[Y] Yes [A] Yes to All [N] No [L] No to All Suspend [?] Help
(default is "Y"):
I've also tried setting $ConfirmPreference="none" or
$ConfirmPreference="high" but the prompt still appears
Can anyone think of a way to suppress the prompt or automatically answer "A"
so I can run this unnattended?
Many thanks
Peter Lawton
S
Shay Levi
I recreated your scenario and tried various commands, none helped, including
setting $ConfirmPreference to "none".
Then I tried to make the change through the GUI. The confirm dialog
appears even in the GUI.
I guess the Exchange team refers to this as a significant change, thus you
cant
avoid the dialog.
HTH
Shay
http://scriptolog.blogspot.com
> because I can't suppress the confirmation prompt. I've tried asking in
> an exchange group but nobody there could help.
> "Default Policy"
> Confirm
> folders
> to
> older
> than
> task to
> managed
> (default is "Y"):
> answer "A" so I can run this unnattended?
> Many thanks
> Peter Lawton
M
Marco Shaw
> "Default Policy"
> Confirm
> to
> than
> (default is "Y"):
WScript has some funtionality to send key strokes to the screen:
http://www.devguru.com/Technologies/wsh/quickref/wshshell_SendKeys.html
Just for fun, I used AutoIt:
PSH>$autoit=new-object -comobject autoitx3.control
PSH>$autoit.send("write-host `"test`"");$autoit.send("{ENTER}")
PSH> write-host "test"
test
PSH>
You could likely write a dynamic script that does a repeated loop and
sends the proper key strokes to the PowerShell console.
That being said, you might want some kind of error control, but you
might just be able to do a start-transcript/stop-transcript and review
the console log to make sure all was well...
Marco
PowerGadgets MVP
http://www.powergadgets.com/mvp
Blog:
http://marcoshaw.blogspot.com
P
Peter Lawton
I was afraid of that it's an Exchange team "feature", my suspicion is that
when they created the custom warning about versions of Outlook they forgot
to make it honour any of the standard confirm supression :(
"Shay Levi" <no@addre.ss> wrote in message
news:8766a944557c8c9b47e4b97aa18@news.microsoft.com...
>including
> cant avoid the dialog.
> HTH
> Shay
>> "Default Policy"
>> Confirm
>> folders
>> to
>> older
>> than
>> task to
>> managed
>> (default is "Y"):
>> Many thanks
>> Peter Lawton
S
Shay Levi
BTW, does it prompts for each user in the pipeline or just for the first one?
Shay
> that when they created the custom warning about versions of Outlook
> they forgot to make it honour any of the standard confirm supression
>> including
>> thus you cant avoid the dialog.
>> HTH
>> Shay
>>> in an exchange group but nobody there could help.
>>> -ManagedFolderMailboxPolicy "Default Policy"
>>> Confirm
>>> folders
>>> to
>>> older
>>> than
>>> task to
>>> managed
>>> Help
>>> (default is "Y"):
>>> Many thanks
>>> Peter Lawton
P
Peter Lawton
It prompts for the first user it comes to that hasn't already got a policy
set, if I answer "Y" to that it'll prompt again at the next one, if I answer
"A" to that it'll run through all the users OK, so I really need to send it
an "A"
Peter Lawton
news:8766a94455b68c9b4881e250f44@news.microsoft.com...
> one?
> Shay
>>> including
>>> HTH
>>> Shay
>>>> Confirm
>>>> folders
>>>> to
>>>> older
>>>> than
>>>> task to
>>>> managed
>>>> Help
>>>> (default is "Y"):
>>>> Many thanks
>>>> Peter Lawton
S
Shay Levi
In DOS we could do something like
command < ECHO A
But the input redirection is not implemented in PowerShell v1.0 :(
Shay
> policy set, if I answer "Y" to that it'll prompt again at the next
> one, if I answer "A" to that it'll run through all the users OK, so I
> really need to send it an "A"
> Peter Lawton
>> first one?
>> Shay
>>> is that when they created the custom warning about versions of
>>> Outlook they forgot to make it honour any of the standard confirm
>>> supression :(
>>>> including
>>>> HTH
>>>> Shay
>>>>> asking in an exchange group but nobody there could help.
>>>>> Confirm
>>>>> folders
>>>>> to
>>>>> older
>>>>> than
>>>>> "Set-CASMailbox"
>>>>> task to
>>>>> managed
>>>>> Help
>>>>> (default is "Y"):
>>>>> Many thanks
>>>>> Peter Lawton
P
Peter Lawton
#8
Someone on anotehr group gave me a way to do it now, seems that this
particular Exchange command needs a special switch
"-ManagedFolderMailboxPolicyAllowed" to suppress the confirmation
(standards - we've heard of them ;-)
Get-mailbox | Set-Mailbox -ManagedFolderMailboxPolicy "Policy
Name" -ManagedFolderMailboxPolicyAllowed
Peter Lawton
"Shay Levi" <no@xxxxxx> wrote in message
news:8766a94455f38c9b48ba3356b4a@xxxxxx
> command < ECHO A
> Shay
>> Peter Lawton
>> news:8766a94455b68c9b4881e250f44@xxxxxx
>>> first one?
>>> Shay
>>>> supression :(
>>>> news:8766a944557c8c9b47e4b97aa18@xxxxxx
>>>>> including
>>>>> HTH
>>>>> Shay
>>>>>> Confirm
>>>>>> folders
>>>>>> to
>>>>>> older
>>>>>> than
>>>>>> "Set-CASMailbox"
>>>>>> task to
>>>>>> managed
>>>>>> Help
>>>>>> (default is "Y"):
>>>>>> Many thanks
>>>>>> Peter Lawton
M
Mike Parrish
#9
I used the -ManagedFolderMailboxPolicyAllowed parameter to supress the
> "Default Policy"
> Confirm
> to
> than
> (default is "Y"):
> Many thanks
> Peter Lawton
