SVCHOST.exe using a lot of memory
S
smicale
I am seeing a SVCHOST.exe using a about 116,360K of memory on my Vista
machine. I have ran all my ONECare antivirus/spyware tools and nothing is
coming up as a problem. I see that the Super Fetch service seems to be the
one that is hogging all this memory. When I stop that service it releases
the memory. Is this normal? What can I do to fix it? Thanks!
M
Malke
smicale wrote:
> It appears the problem is with the SysMan service. Does this service need
> to be running?
It's not a Windows process and in fact may be a trojan:
http://www.google.com/search?hl=en&q=SysMan&btnG=Search
What does a good malware/virus scanning get you? (I don't include OneCare in
that terminology.) Be sure the machine is clean:
http://www.elephantboycomputers.com/page2.html#Removing_Malware
Malke
MS-MVP
Elephant Boy Computers - Don't Panic!
FAQ - http://www.elephantboycomputers.com/#FAQ
S
smicale
sysman is not a process running on my machine, it is a service. Do you think
this is still mailware or a virus?
"Malke" wrote:
> > to be running?
> Malke
> MS-MVP
M
Malke
> think this is still mailware or a virus?
A process is the same as a service so Sysman is most definitely running on
your machine. I cannot see your computer from here so I cannot guess
whether you have malware. That's why I gave you the link to malware removal
steps. If you haven't gone through the thorough steps, you have no way of
knowing whether your machine is clean. I suspect it isn't, but that's only
an educated guess based on many years of working on Windows machines.
Standard disclaimer: I can't see and test your computer myself, so these are
just suggestions based on many years of being a professional computer tech;
suggestions based on what you've written. You should not take my
suggestions as a definitive diagnosis. If you can't do the work yourself
(and there is no shame in admitting this isn't your cup of tea), take the
machine to a professional computer repair shop (not your local equivalent
of BigComputerStore/GeekSquad). If possible, have all your data backed up
before you take the machine into a shop.
Malke
MS-MVP
belgradar
1
its perfectly normal its just the superfetch you can turn superfetching of inthe service panel. if you do that svhost process will dissapear. try it if you want to test it. but thats what it is. superfetch just uses lots of memory.
