sys error
A
Andrew McLaren
"paulb" <paulb@xxxxxx> wrote...
> everytme i start up windows i get an error message: "Can't open AsIO.sys
> (2)"
ASIO.SYS is installed by an Asus utility - maybe "AI Booster" or "PC Probe"?
Anyway, it's not a Vista- or Microsoft-supplied file.
It looks like that error message is very common, for users with Asus
boards - judging from a quick Google.
Hope it helps a bit,
Andrew McLaren
amclar (at) optusnet dot com dot au
P
paulb
What do i do, just live with it and just keep clicking ok? :)
> > (2)"
> Andrew McLaren
A
Andrew McLaren
Sure, that's one strategy :-)
Well, although you are seeing this problem on a machine running Vista, this
is not a Microsoft-supplied file and it is not part of any Vista component;
and the problem seems to occur frequently on XP machines as well. Since is
is an Asus-supplied file, the 2 main strategies I'm envisage are:
- identify the Asus utility which AsIO.sys belongs to, and uninstall it; or
- look on an Asus support forum, for information on how to correct or remove
the error. Asus forums are at:
http://vip.asus.com/forum/topic.aspx?board_id=1&SLanguage=en-us
Hope it helps,
Andrew McLaren
P
paulb
It looks like a setup.inx file when i type AsIO into the search field in
"computer"
> Hope it helps,
> Andrew McLaren
