System.exe "NT kernel & system" suss?
jons
I have a process called "System" with description "NT kernel & system"
Seems a bit suss?
Some exe sites have users all saying its got to go, ms answers said similar.
Looking for some answers as to what this is?
thanks.
    it 870
    GT220
    30" + 24"
    1600p
    old 320GB
richc46
townsbg
~~тσωηsвg~~
Seems a bit suss?
thanks.
That is probably the windows kernel which is the very core of the operating system. Your operating system can't function without it. If it'll make you feel better you can scan your computer with a good anti virus and malwarabytes. If you wish you can try clicking on view and then select columns. Check PID (Process Identifier) and then ok. For the entry in question if under the PID column the number is very low (mine is 4; it may very for you) then it is more likely that it is the kernel. If you find that it is something else or you right click on it, select properties, and you find that the location is somewhere other than Windows than it is probably a virus. As for me, selecting properties brings up nothing. Try looking up the process identifier and attempting to look up the properties and let us know what you find.
    Windows 7 Pro x64
    Mid 2010 iMac
    Quad core 3.2 Ghz Intel I3
    8 gb
    ATI Radeon HD 5670 512 mb ram
    1920x1080 and 1440x900
    1 TB
    N/A
    Windows 2008 R2 Enterprise
    Compaq Presario SR5350F
    Pentium 2.0 gHZ Dual core E2160
    2 gb
    1440 x 900
    300 GB
niemiro
Banned
Seems a bit suss?
thanks.
I sorry but I don't understand your question? What do you mean by suss?
I think it means suspicious, and there is no valid system file called system.exe.
    Dell XPS 420
    Stock Dell 0TP406
    4 gb (DDR2 800) 400MHz
    1600 x 1200 and 1280 x 1204
    1 x 640Gb (SATA 300)
    1 x 1Tb (SATA 600)
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
townsbg
~~тσωηsвg~~
If you'd note the OP didn't say system.exe but said System. I have the same thing and my system is clean. It is probably the windows kernel.
    Windows 7 Pro x64
    Mid 2010 iMac
    8 gb
    1 TB
    N/A
    2 gb
    1440 x 900
    300 GB
richc46
Seems a bit suss?
thanks.
Agreed
niemiro
Banned
Well, if you look at the thread title, you will see a different story. Let's find out whether the source of the OP's information EXPLICITLY included ".exe".
    Dell XPS 420
    Stock Dell 0TP406
    1 x 1Tb (SATA 600)
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
townsbg
~~тσωηsвg~~
Agreed.
    Windows 7 Pro x64
    Mid 2010 iMac
    8 gb
    1 TB
    N/A
    2 gb
    1440 x 900
    300 GB
jons
thanks for help everyone.
Just says system, not exe.
Still showed on clean boot, so i guess its part of windows & important?
    it 870
    GT220
    30" + 24"
    1600p
    old 320GB
richc46
Try in safe mode
