System.Int64 WorkingSet {get;}
B
bluefin
The abovementioned is one of the definitions found in
System.Environment class.
See the following PS code:
Code:
PS R:\> [environment]::WorkingSet
12578816
Q1. 'WorkingSet' is a static property in technical term. What is the
meaning of 'WorkingSet' in layman term?
Q2. The result shows '12578816', which I think it is in terms of
bytes, but what does it refer to?
cheers
F
Flowering Weeds
> 12578816
PS> (get-process -id $pid).workingset
14426112
PS> [environment]::WorkingSet
14434304
PS> [environment]::WorkingSet / 1024
14104
PS> (get-process -id $pid).workingset / 1024
14236
PS> get-process -id $pid
Handles NPM(K) PM(K) WS(K) VM(M) CPU(s) Id ProcessName
776 5 37080 14364 126 2.14 3244 powershell
"Environment::WorkingSet" - Live Search
http://search.live.com/results.aspx?q="Environment::WorkingSet"
Remember, Windows PowerShell is a
Windows admin's automation tool (now
GUI based).
B
bluefin
Thanks for quick response. According to your get-process status, WS
isn't the same as WorkingSet, or else what? What is the definition of
WS? Appreciated if you could explain the difference between WS Int32
and Int64.
Cheers
> > 12578816
> 14426112
> 14434304
> 14104
> 14236
>     776       5    37080      14364   126     2..14   3244 powershell
> "Environment::WorkingSet" - Live Searchhttp://search.live.com/results.aspx?q=%22Environment%3A%3AWorkingSet%22
> GUI based).
T
Thomas Lee
In message
<046374a6-b032-4843-a6b2-dc0d9ae2ae4e@xxxxxx>,
bluefin <desertcamel.chen@xxxxxx> writes
Code:
>12578816
In a virtual memory system (which include Windows), a process has a
large virtual memory space, but often much/some of that virtual memory
is not actually in use. The part of the virtual memory that is in
physical memory is the working set.
Windows constantly attempts to trim the working set (freeing up
physical memory for other processes). Sometimes the aspplication
running in the process does not need the page(s) that the memory manager
just trimmed. Other times, the application does need the page(s) and
take the pages back.
Hope this makes sense.
Thomas
Thomas Lee
doctordns@xxxxxx
B
bluefin
Thanks for your effort to explain complex thing in plain English. I
prefer explanation in this way, rather than with codes.
Thomas Lee wrote: '... The part of the virtual memory that is in
physical memory is the working set.'
Thus, the WS is referenced to physical memory, not program memory just
what jvierra replied in scriptinganswers.com
Hope not offending anyone
On Dec 14, 9:30 am, Thomas Lee <t...@xxxxxx> wrote:
> In message
> <046374a6-b032-4843-a6b2-dc0d9ae2a...@xxxxxx>,
> bluefin <desertcamel.c...@xxxxxx> writes
Code:
> >12578816
> Thomas
> Thomas Lee
> doctor...@xxxxxx
