System.net tracing
A
I have been using system.net tracing with powershell v2 without issue on my
Vista desktop without issue.
However, when I try it on w2k3 server sp2 and powershell v1 I get no file
created and nothing in dbgview. I have tried several servers with different
builds. Does anyone know if there are issues using system.net tracing with
powershell v1 on w2k3 sp2?
I am using the powershell.exe.config file below
Thanks.
<configuration>
<system.diagnostics>
<sources>
<source name="System.Net" tracemode="includehex"
maxdatasize="1024">
<listeners>
<add name="System.Net"/>
</listeners>
</source>
<source name="System.Net.Sockets">
<listeners>
</listeners>
</source>
<source name="System.Net.Cache">
<listeners>
</listeners>
</source>
</sources>
<switches>
<add name="System.Net" value="Verbose"/>
<add name="System.Net.Sockets" value="Verbose"/>
<add name="System.Net.Cache" value="Verbose"/>
</switches>
<sharedListeners>
type="System.Diagnostics.TextWriterTraceListener"
initializeData="network.log"
</sharedListeners>
<trace autoflush="true"/>
</system.diagnostics>
</configuration>
R
RichS [MVP]
Check that you have the same versions of .NET on Vista and Win 2003
Richard Siddaway
All scripts are supplied "as is" and with no warranty
PowerShell MVP
Blog: http://richardsiddaway.spaces.live.com/
PowerShell User Group: http://www.get-psuguk.org.uk
"Adam" wrote:
> Hi,
> Thanks.
> <configuration>
> <sources>
> maxdatasize="1024">
> <listeners>
> </listeners>
> </source>
> <listeners>
> </listeners>
> </source>
> <listeners>
> </listeners>
> </source>
> </sources>
> <switches>
> </switches>
> <sharedListeners>
> </sharedListeners>
> </configuration>
A
Hi Richard,
both versions have .Net 2 and I did run filemon and saw it accessing the
version 2 .net dll's. This functionality was supposedly introduced in .net
framework v2 and so I would have thought it should work both v1 and v2 of
powershell as they are both built on top of v2. I thought there might have
been something I was missing on the server side but I haven't found
anything. I think I will park this one until I have more time to build some
test environments.
Cheers,
Adam.
"RichS [MVP]" <RichSMVP@xxxxxx> wrote in message
news:F6B5F729-182D-4F88-B27E-0FAF7A351116@xxxxxx
> Richard Siddaway
> PowerShell MVP
> "Adam" wrote:
>> Hi,
>> my
>> different
>> with
>> Thanks.
>> <configuration>
>> <sources>
>> maxdatasize="1024">
>> <listeners>
>> </listeners>
>> </source>
>> <listeners>
>> </listeners>
>> </source>
>> <listeners>
>> </listeners>
>> </source>
>> </sources>
>> <switches>
>> </switches>
>> <sharedListeners>
>> </sharedListeners>
>> </configuration>
