system properties doesn't show hardware configuration! HELP!
  • Thread starter This is so annoying.....
  • Start date
T
I'm running Windows Vista Ultimate 32-bit. I have a Dual-Core processor with
1.83GHz and 2GB of RAM. My system rating is 4.6. The only problem is, when I
go to my system properties in the control panel, it doesn't show any of this.
after "Rating:" it's just a blank space. "Processor: Not Available", "Memory
(RAM): Not Available). it shows me my system type but that's it. I know it
recognizes it because the welcome is able to show it (RAM and processor). Is
there a setting I changed somewhere that's causing this? How can I get it to
show these again? Will SP1 solve this problem? Please help
M
Mick Murphy
Start> Right-click on Computer>Properties.
Mick Murphy - Qld - Australia
T
That's where it's not showing it that it's supposed to.
A
azntom616
1- Open Command Prompt
2- At the Command Prompt enter the following command exactly as
written:
net localgroup "Administrators" "NT Authority\Service" /add
then press enter and you should be ready to go. It worked like a charm
for
me on the two PC's that were having the exact same problem......
i got this from the vistax64 site
it worked for me so i hope it works for other people
azntom616
azntom616's Profile: http://forums.techarena.in/members/azntom616.htm
View this thread: http://forums.techarena.in/vista-help/930392.htm
