System Restore, Task Manager and other applications won't work
DanA
I am using Vista Ultimate x64 Build 6001 SP1.
Intel® Core(TM)2 CPU 6700 @ 2.66GHz 2.66 GHz Memory (RAM) 4.00 GB
The behavior described below started suddenly, apparently after I reinstalled VS 2005.
Some of the symptoms are:
  • When I click on System Restore I get (as expected) the dialog box “Windows needs your permission to continue” ; I click Continue. Apparently nothing happens.
    I repeat the above and I get the message “The System Restore wizard is already running.” However, it is not visible.
  • Task Manager also remains invisible.
  • When I click on “Turn Windows features on and off” the “Windows Features” box is displayed with “Please wait...” but nothing happens.
  • When trying to uninstall an update, Windows Installer displays "Preparing to install..." and remains so forever. Click Cancel, after 10 min or so “Install server is not responding”.
  • Frequently Visual Studio and the Office 2007 programs go in No responding mode and I must reboot.
  • When I shut down the computer "Logging off " is displayed until I use the hardware shut down button.
  • Chkdsk found nothing wrong.
  • Sfc /scannow doesn’t start.
  • The same in Safe Mode.
  • When I try to start from the DVD the Vista background is displayed with the mouse cursor but then nothing.
Is there a way out?
Thank you very much,
Dan
T
Tony UK
I am no expert. But if that happened to me, I would want to run an updated
antivirus program before trying anything else. Mind you, in the same
circumstances I would be thinking of wiping the hard drive and rebuilding the
whole computer from scratch. Assuming, of course, that you have backed up
your data first.
> - When I click on System Restore I get (as expected) the dialog box
> “Windows needs your permission to continue†; I click Continue.
> is already running.†However, it is not visible.
> - Task Manager also remains invisible.
> - When I click on “Turn Windows features on and off†the “Windows
> Features†box is displayed with “Please wait...†but nothing happens.
> - When trying to uninstall an update, Windows Installer displays
> 10 min or so “Install server is not respondingâ€.
> - Frequently Visual Studio and the Office 2007 programs go in No
> - When I shut down the computer "Logging off " is displayed until I
> - Chkdsk found nothing wrong.
> - Sfc /scannow doesn’t start.
> - The same in Safe Mode.
> - When I try to start from the DVD the Vista background is displayed
> Is there a way out?
> Dan
> DanA
