Task Manager has changed and does not function correctly
U
USAOz
For some unknown reason (but after the most recent 25/9/08) automatic windows
update, my Task Manager does not appear or function correctly.
When I press Ctrl-Alt-Del to invoke the Task Manager, I no longer get the
screen with all the tabs at the top, instead I get only a white window with
the currently running tasks showing. I can NOT do ANYTHING in this window -
nor even switch tasks asI used to be able to do!
I cannot close this window unliss I right-click the system toolbar icon.
I cannot even log-off or restrart as I used to be able to do in this window.
Any ideas about what's happened and more importantly, how to correct this
sitaution and restore the Task Manager to Windows installed default?
M
Mark L. Ferguson
Task Manager Menu Bar and Tabs Are Not Visible:
http://support.microsoft.com/kb/193050/en-us
Please use the Communities guidelines when posting.
http://www.microsoft.com/wn3/locales/help/help_en-us.htm
Use the "Ratings" feature. It helps the new users.
Mark L. Ferguson MS-MVP
https://mvp.support.microsoft.com/profile/Mark.Ferguson
"USAOz" <USAOz@xxxxxx> wrote in message
news:9E1AE131-1AB8-4E9D-9E45-2CC9ECD47E17@xxxxxx
> windows
> with
> window -
> window.
P
Paul Montgumdrop
You can do a system restore back to a point prior to the updates you
have mentioned to correct the problem, possibly. You can also do the
updates manually to pinpoint what update has caused you problems.
Keep in mind now that when a user starts having problems with Task
Manager, it's usually malware that is the culprit.
Brink
Staff member
mvp
32,205
Location
Oklahoma, USA
Hello USAOz,
It sounds like you may have Task Manager in small footprint mode. This tutorial will help show you how to get out of it to go back to normal mode.
http://www.vistax64.com/tutorials/114377-task-manager-small-footprint-mode.html
  • Show second system?
    Yes
    Operating System
    ASUS Maximus X Code Z370
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    250GB Samsung 960 EVO M.2,
    256GB OCZ Vector,
    6TB WD Black WD6001FZWX
    Corsair Air 740
    Logitech MX Master
    Creative F200 webcam,
    Linksys EA9500 router,
    Arris SB6190 cable modem,
    APC SMART-UPS RT 1000 XL,
    Lumia 1520 phone
R
Richard Urban
This has nothing to do with malware and everything to do with the fact that
the O/P changed the mode of operation for Task Manager without realizing it.
Richard Urban
Microsoft MVP
Windows Desktop Experience
"Paul Montgumdrop" <Paul@xxxxxx> wrote in message
news:%23GvTMGKIJHA.788@xxxxxx
>> windows update, my Task Manager does not appear or function correctly.
>> with the currently running tasks showing. I can NOT do ANYTHING in this
>> window - nor even switch tasks asI used to be able to do!
>> window.
> You can do a system restore back to a point prior to the updates you have
> mentioned to correct the problem, possibly. You can also do the updates
H
HappyAndyK
Simply double click somewhere in the light grey border area :)
> windows
> the
> with
> window -
> icon.
> window.
> this
HappyAndyK
www.WinVistaClub.com
HappyAndyK's Profile: http://winvistaclub.com/forum/member.php?userid=4
View this thread: http://winvistaclub.com/forum/showthread.php?t=23007
S
silver hair
Hi there
In my Vista Home Basic 32 bit (86)
I push Ctrl Shift Esc and Windows Task Manager opens
lucky me I guess
P
Paul Montgumdrop
#8
> Seems like a rather severe remedy for correcting a known display
> option of the Task Manager.
> There's no malware involved; the OP simply accidentally
> double-clicked the Task Manager's border, and now need only repeat the
> action to reverse the toggle and restore the Task Manager's normal
> interface.
I didn't even know that Task Manager had some kind of small foot print.
I based it on the information given and past incidents of Task Manager
being taken-out by malware so the user could not see or do anything by
using TM, which was always the case on other MS Windows O/S platforms.
U
USAOz
#9
Thank you VERY much for that useful and correct solution!
As was indicated in the sub-discussions to this post, I - like many others -
was not even aware of this "tiny footprint" option! Why would you even WANT
it? As it seems that MS had "under-documented" it and its solution, you
would think they WOULD document it or put a fix or restore default option in
the Task Manager!
Again - thanks heaps!
90
Location
Barcelona, SPAIN
#10
Oh nice, I was just looking for something like that! ctrl alt del was driving me nuts (that stupid extra step imho)
    INTEL CORE 2 QUAD Q6600
    ASUS P5K-E WIFI P35
    8GB DDR2 667MHZ KINGSTON
    Nvidia Geforce 8800GTS 512MB G
    1 x Western Digital 500GB 16MB SATA2
