Task Manager
J
JamesPB
What happens when I click on Task Manager/View/Update Speed/and set it to
High? It was set to Normal. Are there any adverse affects by changing it to
High? Why would I not want it to be set to High? Does it adversely affect
graphics resolution?
JamesPB
Brink
Staff member
mvp
Hi James,
Setting this option to high will have the information displayed in the Task Manager to be updated in real time instead of the other options (every so often). On high it will use more of your available resources to keep it updated more often. Depending on how fast your computer is, you may or may not notice the extra use of these resources.
JamesPB
P
PaulB
Hi James,
As far as I know it just increases the update of the data (to get it more
often).
I'm not sure why you would need it faster. If you do set it at the high
rate, it will use more system resources, thats all.
Paul
> JamesPB
