Taskbar Notification Area Network choice greyed out
S
saroehr
I have been reading all the posts regarding this issue. My network location
icons
no longer show in the notification area. Suprisingly, the checkbox for
network is
greyed out in the taskbar settings.
Has a resolution for this issue been found?
Thanks!
Scott
S
ssfurrell
I am having the same issue and it happend after the last intel bio's update
and came back the next day, now it is not showing up at all along with
volume, Network, and Power. I am run Windows Vista Ultimate 64 bit on a 965
intel board anyone have any suggestions?
> icons
> network is
> Thanks!
> Scott
W
Wayne
I tried this which I got from another internet site and it worked.
run 'regedit.exe'
goto key 'HKEY_CURRENT_USER\Software\Classes\LocalSettings\Software\
Microsoft\CurrentVersion\TrayNotify'
delete keys 'IconStreams' & 'PastIconsStream'
Start task manager, go to process and kill explorer.exe
go to applications in the task manager, hit new task and type
'explorer.exe'
explorer will now reboot and your icons should return. I had to go
to task manager and check the network and volume buttons.
Hope it works for you.
Wayne
Posted via http://www.vistaheads.com
D
darksamus
Thanks a lot. I looked all over here trying to find this solution. Problem
only occured after Vista (Ultimate) SP1 update. I'm glad this helped fix this
issue.
> run 'regedit.exe'
> 'explorer.exe'
> Wayne
Brink
Staff member
mvp
32,205
Location
Oklahoma, USA
  • Show second system?
    Yes
    Operating System
    ASUS Maximus X Code Z370
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    250GB Samsung 960 EVO M.2,
    256GB OCZ Vector,
    6TB WD Black WD6001FZWX
    Corsair Air 740
    Logitech MX Master
    Creative F200 webcam,
    Linksys EA9500 router,
    Arris SB6190 cable modem,
    APC SMART-UPS RT 1000 XL,
    Lumia 1520 phone
