taskbar sliding animation
G
Gernot Frisch
my taskbar is auto-hidden, and when it comes up, it's doing a slide-in
animation, which is very annoying.
How can I make my taskbar pop-up immediately?
I've seen there's some tip to disable viewing the contents of moving
windows, but that's even more annoying.
Gernot Frisch
http://www.glbasic.com
M
Mamamegs [MS MVP]
Gernot Frisch explained on 20-2-2008 :
> Hi,
> slide-in animation, which is very annoying.
Go to System Properties > Visual Effects and remove the tick from 'Fade
or slide menus into view'.
Mamamegs.
Problemen met Windows Vista? www.vistabits.nl
Windows Vista Problems? www.vistabits.info
Control Panel/System>Advanced system settings/Performance Settings
Button/Visual Effects Tab>untick whatever sliding/fading you don't want.
Maxwell Bluemeanie
"Gernot Frisch" <me@xxxxxx> wrote in message
news:622d37F21ik35U1@xxxxxx
> Hi,
