Test-Path isValid parameter
S
Shay Levi
From the help file
-isValid <SwitchParameter>
Determines whether the syntax of the path is correct, regardless of whether
the elements of the path exist. Returns TRUE if the
path syntax is valid; FALSE if it is not.
Should I rely on Test-Path's -isValid parameter ???
PS C:\Scripts> Test-Path c:\ -isValid
True
PS C:\Scripts> Test-Path c:\]] -isValid
True
PS C:\Scripts> Test-Path c:\\\ -isValid
True
PS C:\Scripts> Test-Path \\\ -isValid
False
PS C:\Scripts> Test-Path z\\\ -isValid
True
PS C:\Scripts> Test-Path z\\\// -isValid
True
PS C:\Scripts> Test-Path shay-levi -isValid
True
Shay
http://scriptolog.blogspot.com
O
Oisin Grehan
On Sep 19, 6:26 pm, Shay Levi <[email protected]> wrote:
> From the help file
> True
> True
> True
> False
> True
> True
> True
> Shayhttp://scriptolog.blogspot.com
should you rely on it for what, exactly? it's about syntactic
validity, not exists etc.
- Oisin
K
Kiron
The -isValid switch parameter checks for the presence of 'invalid' filename
characters...
....if present it returns $false.
32..255|?{!(test-path "$([char]$_)" -isValid)}|%{[char]$_}
Could be used to ensure the validity of randomly generated file names for
example.
Kiron
K
kirk
> characters...
> example.
Hi Kiron,
I agree, although note that if you use
[System.IO.Path]::GetRandomFileName() you get a nice random filename
that contains only safe characters:
http://pageofwords.com/blog/default.aspx?page=admin
Kirk
S
Shay Levi
Thank you guys.
Shay
> From the help file
> of whether
> True
> True
> True
> False
> True
> True
> True
> Shay
