The type and value of an empty pipeline
D
DioGenus
I would intuitively think that since the output from a pipeline normally is
an array, the "output" from an empty pipeline should be the empty array @().
E.g.
PS> ( @(1,2) | % { $_ } ).GetType()
IsPublic IsSerial Name BaseType
True True Object[] System.Array
is an array while
PS> ( @() | % { $_ } ) -eq $null
True
Can anyone explain why $null is a better choice than @()? In my scripts, I
now have to perform extra testing before I can add the output of a pipeline
to an existing array since the following statement would just add a $null
element to $myArray if $maybeEmptyArray is empty:
$myArray += @() + $maybeEmptyArray | % { doProcess $_ }
I obviously want nothing added to $myArray if $maybeEmptyArray is empty.
S
stej
Yes, this is a little bit unfortunate.
But there is a quick fix:
$maybeEmpty = @( @() | % { $_ } )
so
@( @() | % { $_ } ).Length -eq 0
On May 21, 12:35 pm, DioGenus <[email protected]>
> E.g.
> is an array while
>     True
D
DioGenus
Exactly what I needed! Thanks!!! I spent quite a bit of time hunting down
this "bug" in my code and truly appreciate that I don't have to add an
explicit test for each such array addition.
DioGenus
> so
> > E.g.
> > is an array while
> > True
