There must be a way.......
F
five256
There must be a way to be sure all Vista and W7 system files are signed
(not corrupted). I've researched and have not found a way. Can anybody
help?
Jonathan_King
    Jonathan King
    AMD Athlon Dual Core Processor 4850e overclocked @ 2.92 GHz
    ASRock A780 FullDisplayPort
    6.0GB Dual-Channel DDR2 290MHz Crucial Technology
    ATI 3200 (onboard), nVidia 7200 GS (PCIe)
    17" Cybervison ds69T, 17" Starlogic
    1024x768
    WD 320GB SATA, Hitachi 1TB SATA
    Antec ea-430d 430W
    Antec 300
    stock cpu, 120mm rear, 140mm top
    Microsoft Wired Desktop 500 (USB)
    Microsoft Wired Desktop 500 (PS/2)
    9.32 Mb/s download; 0.36 Mb/s upload
    Other OS's:
    Windows 7 Professional x64, Windows Professional x86, Ubuntu x64
F
five256
On Mon, 29 Mar 2010 15:25:06 -0500, Jonathan King
>> help?Hello,
>Try the SFC commmand. See this tutorial: 'SFC /SCANNOW Command - System
>File Checker - Windows 7 Forums'
>(http://www.sevenforums.com/tutorials/1538-sfc-scannow-command-system-file-checker.html)
Thank you. However, I've done exactly that and it stops at 56% and a
message tells me that it cannot complete or perform this process. Do you
know of any way to find out why it does this? Thanks again....
Jonathan_King
    Jonathan King
    1024x768
    Antec ea-430d 430W
    Antec 300
    Other OS's:
Jonathan_King
I believe it should be the same for Vista. Simply perform an Upgrade while in Windows.
    Jonathan King
    1024x768
    Antec ea-430d 430W
    Antec 300
    Other OS's:
Jonathan_King
On Mon, 29 Mar 2010 20:56:28 -0500, Jonathan King
>while in Windows.
Do you know if there are any risks?
No, no risks. You may notice you need to set up internet explorer again, but your programs and data will not be touched.
    Jonathan King
    1024x768
    Antec ea-430d 430W
    Antec 300
    Other OS's:
F
five256
On Tue, 30 Mar 2010 06:50:46 -0500, Jonathan King
>> > >while in Windows. > > Do you know if there are any risks?No, no risks. You may notice you need to set up internet explorer again,
Thank you.
