Tool menu bar
C
Cal Bear '66
Press the Alt. key on your keyboard.
I Bleed Blue and Gold
GO BEARS!
"Jim Riekel" <JimRiekel@xxxxxx> wrote in message
news:2CA40362-5AFE-4FC7-ADCD-9C6BD2A51723@xxxxxx
>I cannot find the Tolls menu bar on the main page, please help me locate it?
F
Frank Saunders, MS-MVP IE
>it?
Tools bar or menu bar?
Frank Saunders, MS-MVP IE, OE/WM
I won't answer email.
Brink
Staff member
mvp
  • Show second system?
    Yes
    Operating System
    ASUS Maximus X Code Z370
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    250GB Samsung 960 EVO M.2,
    256GB OCZ Vector,
    6TB WD Black WD6001FZWX
    Corsair Air 740
    Logitech MX Master
    Creative F200 webcam,
    Linksys EA9500 router,
    Arris SB6190 cable modem,
    APC SMART-UPS RT 1000 XL,
    Lumia 1520 phone
Brink
Staff member
mvp
Re: Menu Bar won't show...
I cannot get the menu bar to show for me like, delete, send/receive, etc.
What should I do?
Hi Babble,
This tutorial will show you how to enable the menu bar in Vista.
Menu Bar
    Yes
    Operating System
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    256GB OCZ Vector,
    Corsair Air 740
    Logitech MX Master
    Lumia 1520 phone
G
Gary VanderMolen
This problem may be caused by an incompatible antivirus.
Windows Mail is not compatible with most McAfee
and Norton security programs. Those will need to be
uninstalled, not just disabled.
After uninstalling your non-compatible antivirus, download
and install a more compatible antivirus like the free Avast:
http://www.avast.com/eng/avast_4_home.html
Even compatible antivirus programs will need to have their
email scanning option turned off. For more on this topic see
http://www.oehelp.com/OETips.aspx#3
Gary VanderMolen [MS-MVP WLM]
"Babble" <Babble@xxxxxx> wrote in message news:F9337589-1DA8-4123-A2F5-BFCA0E0EF539@xxxxxx
> What should I do?
F
Frank Saunders MS-MVP IE,OE/WM
#8
> What should I do?
Right click where it says File Edit etc. and click Toolbar to check it.
www.fjsmjs.com
Do not send email
