Tunnel adapter Local Area Connection
S
SwampYankee
Whenever I do an ipconfig I get a bunch of connections that are not
active. It lists my active connections, but then I get a whole series of
these:
Tunnel adapter Local Area Connection* 6:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Tunnel adapter Local Area Connection* 7:
They don't seem to be causing any harm and the only downside is that I
sometimes have to scroll around to find the connection that is active.
What are these?
thanks
S
Synapse Syndrome
"SwampYankee" <1@xxxxxx> wrote in message
news:MPG.22693e6b56a3bad9896bc@xxxxxx
> Hi,
> these:
> What are these?
> thanks
Are you using VirtualPC?
ss.
W
You could Run-> CMD then in DOS, enter>Netsh winsock reset
Need to restart after this.
Could check out more netsh options; also in Defender you can see in Explorer
winsock connections.
S
SwampYankee
In article <eoSkhW$mIHA.5280@xxxxxx>,
synapse@xxxxxx says...
> > Hi,
> > these:
> > What are these?
> > thanks
> ss.
no, just connect to many networks over the last year
R
Robert Pendell
SwampYankee wrote:
> Hi,
> these:
> What are these?
> thanks
Those are the IP4toIP6 translation adapters for the IPv6 protocol in
Vista. They will cause no harm and you can ignore them.
C
Chris Swinney
Just as a matter of interest, i have a total of 27 adapters installed!
Adapters 7-27 are to do with Tunnel Adapters. Why so many? As a mater of
interest, I do have VM Ware installed.
"Robert Pendell" wrote:
> SwampYankee wrote:
> > Hi,
> > these:
> > What are these?
> > thanks
