turn off message "Low Disk Space"
M
Maximka
I have separated partition for swap file, and I see message "Low Disk Space".
How I can turn it off? Please don't suggest to buy new HDD.
R
Ronnie Vernon MVP
You need to either increase the amount of space allocated to the Swap File,
or a better option, let Windows determine the amount to be used.
Ronnie Vernon
Microsoft MVP
Windows Shell/User
"Maximka" <Maximka@discussions.microsoft.com> wrote in message
news:FE6DD5F5-1AEE-4627-BF35-1C542502F23D@microsoft.com...
>Space".
M
Maximka
Why I need to have empty space on swap partition? I want to turn this message
off, I don't need it, I always control free space by myself and I know better
how match free space I need. I can off this message by editing registry in
XP. How I can do this in Vista?
> Ronnie Vernon
> Microsoft MVP
> Windows Shell/User
> >Space".
K
kraut
You ever notice how hard it is in ANY of these news groups just to get
a straight answer to a straight question?!?!
I guess everyone wants to be like MS and tell you how to run your
system and what to do. No one ever want to just answer a persons
question!!
>> >Space".
R
Ronnie Vernon MVP
The question was answered correctly. The best way to deal with a warning
message is to solve the problem, not kill the messenger, wouldn't you agree?
Ronnie Vernon
Microsoft MVP
Windows Shell/User
"kraut" <NewsGroupsPlease@NewsGroupsPlease.org> wrote in message
news:avi123d8vemonecqo5dbf3t7cniab8qom9@4ax.com...
> question!!
>>message
>>better
>>> File,
>>> >Space".
P
Paul Randall
"Ronnie Vernon MVP" <rv@invalid.org> wrote in message
news:0A91F069-DEC8-45AB-9675-CD7EC1A85FB5@microsoft.com...
> agree?
> Ronnie Vernon
> Microsoft MVP
> Windows Shell/User
>> question!!
>>>message
>>>better
>>>in
>>>> File,
>>>> >Space".
If a person dedicates a partition solely to the swap file, which the OP
apparently did, then it seems to me he should be able to set the swap file's
size to the full size of the partition, and the system should not complain
about 'low disk space' in that partition. Am I missing something here? I
think the low disk space message is Windows' complaining that there is no
free space in a partition that has absolutely no need for any free space.
-Paul Randall
R
Ronnie Vernon MVP
"Paul Randall" <paulr901@cableone.net> wrote in message
news:OWHO0mufHHA.1816@TK2MSFTNGP06.phx.gbl...
>> agree?
>> Ronnie Vernon
>> Microsoft MVP
>> Windows Shell/User
>>> question!!
>>>>message
>>>>better
>>>>in
>>>>> File,
>>>>> >Space".
> file's size to the full size of the partition, and the system should not
> complain about 'low disk space' in that partition. Am I missing something
> here? I think the low disk space message is Windows' complaining that
> there is no free space in a partition that has absolutely no need for any
> free space.
> -Paul Randall
Unless you are psychic, I don't think the OP has given any details about the
swap file size in relation to the partition size? :)
He may have the virtual memory set to the same size as the partition where
it resides, but too low for the amount being requested? The low disk space
warning is usually triggered by setting a maximum size for the swap file.
The swap file is dynamic and grows depending on the amount of virtual memory
being requested. It could also be heavily fragmented or even corrupted.
A warning message is not something you want to ignore or simply turn off
because you think it is annoying.
Ronnie Vernon
Microsoft MVP
Windows Shell/User
P
Paul Randall
#8
news:ACB2E1E5-7672-48A9-A905-1828B888AD70@microsoft.com...
>>> agree?
>>> Ronnie Vernon
>>> Microsoft MVP
>>> Windows Shell/User
>>>> question!!
>>>>>message
>>>>>better
>>>>>in
>>>>>> File,
>>>>>> >Disk
>>>>>> >Space".
>> something here? I think the low disk space message is Windows'
>> complaining that there is no free space in a partition that has
>> -Paul Randall
> the swap file size in relation to the partition size? :)
> memory being requested. It could also be heavily fragmented or even
> corrupted.
I'm definitely not psychic :-)
Lets assume the partition is used solely for the swap file, and is 2 or 3
times the size of physical memory, and the swap file is a fixed size that
uses the entire partition. I doubt the nagging about low disk space would
be triggered by the memory manager. I think it is just the 'drive almost
full' nag talked about in http://support.microsoft.com/kb/285107 . With
these assumptions, turning off the nag seems like a reasonable thing to do.
I'm also assuming that the kb285107 nag applies to Vista.
-Paul Randall
cornell2
7
#9
re: Low Disk Space Warning
In defense of the original poster:
I too have a similar (if not the same problem). Bought a compaq notebook with vista pre-installed. Right out of the box this warning persists. And the warning is for drive D: ... the recovery partition.
1. The partition was already there and seems to be part of the standard setup (I check the others at the store).
2. Drive C (my main partition has about 70Gig) plenty free (like 40G avail)
3. Drive D (recovery) is 5.53G .. .with 876kb free.
Yup ... 876kb free. This is the automatic recovery disk, if you will. I have no choice in this... NOR can I delete ANY of the files. It appears the OS sets up this partition the exact size of the recovery files. Makes sense.
What does NOT make sense is that ... every 3 mins I get that annoying bubble warning popping up with a Low Disk Space Warning on Drive D:
I scream at it "Mr. Vista - YOU set up this Disk ... and KNEW it was fully the second you set it up. And furthermore, I cannot and should not delete the files. So why interrupt everything that I am doing every 3 mins?"
I have searched the net ... called compaq (microsoft won't talk to me since the OS came bundled with the computer). People have experience the problem ... but there seem to be no solutions. (I tried all these registry hacks, but they have no effect .... the hacks are probably only affecting drive C).
ALSO ... when I post the problem on different boards - I too get fairly smug and useless answers like "have you tried deleting the files" "you should install linux" ... and generally answers that show that people are more interested in appearing smart than actually reading the question. Sorry folks. I would love a solution and don't want to insult anyone, but I do agree with the OP. The responses can be very frustrating ....
M
Michael
#10
What you need to do is stop Vista from seeing that partition as a disk
drive, don't remove/delete the files just make the 'd:' go away.
(Dell set up does same dumb thing).
Start
Control Panel
System and Maintenance
Create and format hard disk partitions (scroll to bottom to see)
Right click on the "D:" "recovery partition"
Change Drive Letter and Paths
Remove the drive letter, note that this doesn't damage any of the contents,
the recovery partition will still be there if needed just that Vista
no longer sees it as a useful operational drive.
Michael
"cornell2" <cornell2.2pbubx@no-mx.forums.net> wrote in message
news:cornell2.2pbubx@no-mx.forums.net...
> avail)
> files. Makes sense.
> every 3 mins?"
> frustrating ....
> cornell2
cornell2
7
#11
thanks for the help.
But for the life of me I cannot find "Create and format hard disk partitions" ANYWHERE under System and Maintenance. Still searching ...
Start
Control Panel
Michael
> avail)
> files. Makes sense.
> every 3 mins?"
> frustrating ....
> cornell2
cornell2
7
#12
"Create and format hard disk partitions (scroll to bottom to see)"
is not one of the options *anywhere* under system mainentance or for that matter, to be found anywhere on my vista menus (I searched the entire program files and sub folders etc..)
cornell2
7
#13
I'm sorry, but your answer does not make much sense to me. Did you read my detailed question or merely respond to the title of the thread and what you the thought problem was. (again this is the sort of thing the OP complained about, and I agreed).
The question was around this Drive D: that came pre-set as a recovery drive, with literally only a few bytes free. Vista keeps on flagging this drive as full (well of course it is full - the partition was created to be the exact size of the recovery disk).
Ronnie Vernon
Microsoft MVP
Windows Shell/User
>Space".
P
Paul Randall
#14
My Compaq has 902 MB free, 4.87 GB used. I don't get the nag.
I did try removing the drive letter. F11 on bootup still works fine.
-Paul Randall
"Michael" <mexxwalraven@verson.net> wrote in message
news:u9nzB%23xgHHA.4520@TK2MSFTNGP02.phx.gbl...
> Start
> Control Panel
> contents, the recovery partition will still be there if needed just that
> Vista
> Michael
>> avail)
>> files. Makes sense.
>> every 3 mins?"
>> frustrating ....
>> cornell2
C
cquirke (MVP Windows shell/user)
#15
On Sat, 14 Apr 2007 08:43:56 -0400, kraut
Yup. If I had an answer, I'd give it to you; as it is, I'm reading
this because I want to see the answer for my own purposes.
I, too, use the feature set that has been part of MS OSs since MS-DOS
3.x at least - namely, I create different partitions and volumes for
different reasons. I call this "using the product as designed".
I use these volumes for different purposes. Often I know, to the last
5M, how much will fit and what will not, even when the volume is as
large as 200G. If there is to be a low-space warning (which is useful
on volumes where temp, TIF and/or growing pagefiles exist), then for
it to be fully-assed, the threshold should be controllable on a
per-volume basis, and I should also be able to turn it off.
"For every complex question, there's a simple
answer - and it's wrong." H.L. Mencken
