TV card drivers
i'm using windows vista ultimate x64
does any1 know where i can get the vista 64bit drivers for the
AVerMedia TVT5 M779 Internal PAL-SECAM-DVBt Hybrid TV Tuner
i got this card with my dell pc, but cant seem to find them on the dell
website, i cant even locate the card on avermedias suppport site,
appreciate any help you can give.
thanks in adv.
ALi
I found the following using Google it probably is not free:
http://www.drivershq.com/Drivers/De...-M779-Internal-PAL-SECAM/4323/9/Drivers.aspx#
"ALi" <ALi@Junkbox.com> wrote in message
news:%232rfsvcuHHA.4868@TK2MSFTNGP02.phx.gbl...
> thanks in adv.
> ALi
F
freddy
ALI,
If Dell and the vendor of the card haven't provided the Vista 64 bit
drivers, I doubt anybody else will, and certainly not Microsoft. You could
try contacting Dell or the card manufacturer to ask about those drivers.
Other than that, if drivers are not forthcoming, you'll need to buy a Vista
compatible card. It's tough out there.
freddy
> thanks in adv.
> ALi
V
Vista_Support
Yes, No, Yes
news:#2rfsvcuHHA.4868@TK2MSFTNGP02.phx.gbl...
> thanks in adv.
> ALi
2
I raised a helpdesk call with Avermedia for Vista-64 bit drivers for the AVerMedia TVT5 M779 Internal PAL-SECAM-DVBt Hybrid TV Tuner and got the following response
Please go the following and download the driver for M779, before you install the new driver, please remove old AverTV driver and reboot the computer,
http://avmedia.uk.googlepages.com/M779_x64_Drv_V2.4.64.31_LogoVista_Di.zip
And guess what it worked first time, well a big thank you to AverMedia for being prompt and getting it working so quickly.
