Two desktop backgrounds?
cGFrench
Hey guys,
I'm currently running two monitors on my vista home premium, and my pc is setting the desktop background for my primary monitor on my secondary one too, which due to the image looks terrible! :(
I know in XP you used to be able to do something like right click a second image, set as a desktop object, then enlarge to desktop background, giving you a second background for your second screen (or something like that?)
Is a similar thing possible in Vista? I can't find it and my screens hurt my eyes!!! :P
Thanks very much in advance for any replies... :)
archie123
I Tunes hates Me
    XFX 780i
    4GB OCZ PC2-8500C5 DDR2
    Gainward GTX260/216 SLI
    Creative X-FI Xtreme Gamer
    Dell UltraSharp 2209WA 22"
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
livewirepyro
What you could do is use a photo editing program. Make the canvas size equal to the two displays then just drag the two backgrounds you want and fit it accordingly.
Seems like a more manual way, I'm sure there's a basic program out there that can tie two images together for the same propose you want it for -- but if you're looking for a quick fix, this seems like your best bet.
Goodluck =]
edit:
http://www.ewallpapers.eu/search_size/2560x1024-Dual-Monitor
and
http://www.deviantart.com/
Deviant art is blocked, so I can't grab the specific link, but there's a large multi-display section under customization.
    Alienware M17 Laptop
    Intel
    4 gigs
    Ati Radeon x3870 x2
    Seagate 250 GB
    Logitech VX
    Logitech G15
    FioS
cGFrench
thanks very much for your tips guys, display fusion was indeed a good solution, but i'm sure a bit of photoshopping wouldn't have gone amiss failing that! :)
