typing replaces text-fix
J
Jim Macklin
Noticed that typing was replacing text and could not find the
reason or mention in the FAQ on how to fix it.
The fix, open a new message, on the format menu [show all menus
first step] then under Format, select Encoding, Western European
Windows, ISO is the default and the typing replaces text.
Suggest that searching for Help with typing as a keyword should
point to this fix.
F
Fiddler
Are you on medication?
Open a new message????
WHERE?
What program?
typing in WHAT replaces text?
"Jim Macklin" <p51mustang[threeX12]@xxxhotmail.calm> wrote in message
news:471FE9C0-EFCE-47B4-8188-1ACBDD2CDB59@xxxxxx
> Noticed that typing was replacing text and could not find the reason or
> The fix, open a new message, on the format menu [show all menus first
> step] then under Format, select Encoding, Western European Windows, ISO
> Suggest that searching for Help with typing as a keyword should point to
> this fix.
R
Ron Sommer
Hitting the Insert key turns over-type (typing replaces text) off and on.
Ronald Sommer
> this fix.
E
> this fix.
In some programs, pressing the Insert key will toggle between over-write
and insert mode.
Joe =o)
B
Bob I
Hi Jim,
You may want to insert the name of the program you are fixing.
> this fix.
G
Gary VanderMolen
Unless otherwise stated, it should be assumed that the program
under discussion is the 'raison d'être' for this newsgroup,
Windows Live Mail.
Gary VanderMolen, MS-MVP
"Bob I" <birelan@xxxxxx> wrote in message
news:e9eJXqcuIHA.4380@xxxxxx
> Hi Jim,
>> this fix.
