UAC, Shield Icons, and setup programs
A
Anthony Wieser
How does Vista decide that a program is a setup program, and requires
elevation?
I have some installers that don't actually require elevation, yet they're
marked with the little shield icon. Is there a description anywhere of what
actually causes elevation? I can't find an explicit list, and have spent
days searching Google, msdn, and live.com, to no avail.
Does the OS look at the import table for a specific call, is there some
other signature algorithm at work here.
Anthony Wieser
Wieser Software Ltd
D
DevilsPGD
In message <OENVv#[email protected]> "Anthony Wieser"
>elevation?
If the file has a manifest that specifies it's requirements, Vista
honours that. Otherwise, any EXE with "setup" or "update" or a few
other keywords will be elevated, as will an MSI.
Insert something clever here.
D
Dave R.
"DevilsPGD" <[email protected]> wrote in message
news:[email protected]
>>elevation?
>>they're
>>of what
>>spent
>>some
Does anyone know what the full list of keywords is? It would be nice to
know so I can tell our developers to avoid them.
Regards,
Dave
D
DevilsPGD
In message <4[email protected]>
I could swear one of our devels email me the list, but I can't find it
at the moment -- Take a stab at MSDN though...
A
Anthony Wieser
>>elevation?
> honours that.
So can I put a manifest in the same folder as a program to state that it
doesn't require elevation? Otherwise, I assume that I need to use the
manifest tool mt to embed the manifest in the exe?
I found some information here:
http://msdn2.microsoft.com/en-us/library/aa905330.aspx
and here:
http://msdn2.microsoft.com/en-us/library/aa480150.aspx
that might be useful to someone else.
Anthony Wieser
Wieser Software Ltd
D
Dave R.
> In message <[email protected]>
>>to
The only good resource I could find in MSDN was in the MS paper "Windows
Vista Application Development Requirements for User Account Control
Compatibility" which says:
> Installer Detection only applies to:
> 1. 32-bit executables
> 2. Applications without a requestedExecutionLevel
> 3. Interactive processes running as a standard user with UAC enabled
> Before a 32-bit process is created, the following attributes are
> checked to determine whether it is an installer:
> . Filename includes keywords like "install," "setup," "update," etc.
> . Keywords in the following Versioning Resource fields: Vendor,
> Company Name, Product Name, File Description, Original Filename,
> Internal Name, and Export Name.
> . Keywords in the side-by-side application manifest embedded in the
> executable.
> . Keywords in specific StringTable entries linked in the executable.
> . Key attributes in the resource file data linked in the executable.
> . Targeted sequences of bytes within the executable.
> Note
> The keywords and sequences of bytes were derived from common
> characteristics observed from various installer technologies.
Now, a couple of questions come to mind. First, is the list an English
language only list, or does the list contain entries from various
languages. Second, what about the "etc."? I still don't have anything
I can take to our development meetings. <sigh>
I'd really like someone from MS to step up here and clear this up, but I
won't hold my breath.
Regards,
Dave
A
Antoine Leca
Dave R. wrote:
> "Windows Vista Application Development Requirements for User Account
> Control Compatibility" which says:
> English language only list, or does the list contain entries from
> various languages.
IANAMD (... MS developper), so this is just a guess.
Given that the trend is toward MUI technology (one-binary-fits-all, and the
localized content is separated into .mui files which are distributed
separately), I guess the list embedded should include the name for any
language. It makes sense as well, since nothing should prevent say a German
to install a program in her mothertongue on an English-speaking computer.
I notice also that with "instal", you're covering a good number of Romance
language, French Installer, Spanish Instalar, Catalan Instal·lació, etc.
(And yes I am hoping "install", with 2 l's, is a typo or more precisely a
defect introduced into the Word document by the cute AutoCorrect
technology...)
Antoine
