unable to assign drive letters to select partitions
Y
yawnmoth
I plugged in a 2.5" HDD from a dead laptop of mine and although one
partition, I see, was assigned a drive letter, there are two other
partitions that have not been assigned drive letters. One of these
two partitions (described as 'Primary Partition') is, presumably, a
hidden partition off which the laptop's operating system can be
restored. The other partition, described as 'EISA Configuration', is,
at 47mb, a bit too small to contain an OS backup.
Anyway, is there a way I can mount the partitions by assigning them
drive letters and then to browse their contents?
Also, if I right click on any partition other than the 47mb one, I'm
presented with the option of deleting that partition. The 47mb,
however, doesn't present me with any options, when I right click on
it, save for 'Help'. This begs the question... how can I reclaim
that 47mb? It's not a whole lot, I know, but every bit counts...
> partitions that have not been assigned drive letters. One of these two
> partitions (described as 'Primary Partition') is, presumably, a hidden
> partition off which the laptop's operating system can be restored. The
> other partition, described as 'EISA Configuration', is, at 47mb, a bit
You could very easily do that from a Linux Live CD.
> however, doesn't present me with any options, when I right click on it,
> save for 'Help'. This begs the question... how can I reclaim that
Try the gparted Live CD.
©arl
"yawnmoth" <terra1024@xxxxxx> wrote in message
news:4266afe0-3ebb-49f5-87db-9cb10845e085@xxxxxx
I have come across this also .. people have suggested letting vista format
the disk but i need the stuff thats on it
©arl
306 Web Design Templates for just $15
http://www.306templates.com
Y
yawnmoth
Certainly that's an option, but I'd prefer to do it with Windows if at
all possible. It's kinda like... if I wanted a new computer, I could
buy one from an OEM manufacturer, or I could buy the individual
components to build my own. Although the former would certainly be
easier, I'd learn more doing the latter. Same thing with this. I
could do as you suggest with a Live CD very easily, but I'd be
depriving myself of a chance to learn something new if I did...
