Unable To Send Mail
3
I have spent many hours, reviewed, and tried many fixes to no avail. I have tried Windows Live Mail and Windows Mail. I am unable to send from either. I am also unable to send from my SBC accounts. I am able to recieve, except from the SBC account. The error messages are all the same. I am quite sure I have the settings input correctly. I have upgraded from XP to Vista; this seems to be the only common thread. Help would be greatly appreciated. The following is an error message. thank you
Your server has unexpectedly terminated the connection. Possible causes for this include server problems, network problems, or a long period of inactivity. Account: 'd_arendt', Server: 'pop.att.yahoo.com', Protocol: POP3, Port: 995, Secure(SSL): Yes, Error Number: 0x800CCC0F
    Pavillion A1130n
    AMD Athlon 64 3500+
    Don't know
    3 GB
    Don't Know
    Don't Know
    ViewSonic
    Cable
G
Gary VanderMolen
The error message you included represents a receive error.
Please post your send error, which will include the words
"Protocol: SMTP".
The receive error message indicates correct settings, at least
as far as the receive parameters.
"Unexpected" termination is usually caused by interference from an
antivirus program. Which antivirus are you running?
As a minimum, email scanning in the antivirus should be turned off,
although that may not be sufficient to eliminate all bad effects.
In a worst case scenario, your antivirus may need to be uninstalled.
Email scanning in any antivirus should be disabled, for reasons
explained here:
http://thundercloud.net/infoave/tutorials/email-scanning/index.htm
Gary VanderMolen, MS-MVP (Mail)
"aquagrizzly" <guest@xxxxxx-email.com> wrote in message news:aaced3a0e35cb0777ecaf18d26020714@xxxxxx-gateway.com...
> thank you
> aquagrizzly
J
Justyna Majsterek
Uzytkownik "Gary VanderMolen" <gary@xxxxxx> napisal w wiadomosci
news:u14rWh3wJHA.3848@xxxxxx
"Protocol: SMTP".
explained here:
> thank you
> aquagrizzly
G
Gary VanderMolen
Re: entered wrong pop address how do I change it.
Go to Tools, Accounts, select that account, Properties, Servers.
Change the POP3 server name as desired. Click OK.
"Sophia" <sasplint@xxxxxx> wrote in message news:OdD%23E94wJHA.4980@xxxxxx
> How do I change the pop3 mail server address?
3
My antivirus is Windows One Care. The "send" error for the SBC account is as follows:
Unable to send or receive messages for the Sbcglobal (d_arendt) account. Your server has unexpectedly terminated the connection. Possible causes for this include server problems, network problems, or a long period of inactivity.
Windows Live Mail Error ID: 0x800CCC0F
Protocol: POP3
Port: 995
Secure(SSL): Yes
The send error code for the Windows Live Mail is:
The connection to the server has failed.
Subject 'test'
Server: 'smtp.live.com'
Windows Live Mail Error ID: 0x800CCC0E
Protocol: SMTP
Port: 25
Secure(SSL): Yes
Socket Error: 10060
thank you for your help
    Pavillion A1130n
    AMD Athlon 64 3500+
    Don't know
    3 GB
    Don't Know
    Don't Know
    ViewSonic
    Cable
3
Protocol: POP3
Port: 995
Secure(SSL): Yes
Subject 'test'
Protocol: SMTP
Port: 25
Secure(SSL): Yes
Socket Error: 10060
Anybody out there? Email still not functional. Do not know what to do.
thanks
    Pavillion A1130n
    AMD Athlon 64 3500+
    Don't know
    3 GB
    Don't Know
    Don't Know
    ViewSonic
    Cable
