Unable to uninstall a Lexmark printer
J
I am unable to uninstall a Lexmark printer. When I go to programs/uninstall
program, and click on the printer it states that the printer is busy printing
and to try again when it is finished. Ofcourse, this printer is not printing
since it is in a box on the floor. This has been an ongoing issue for three
days. Any suggestions on what to do would be helpful. Thanks
L
LoneWolf
Hi jcf
Try uninstalling the printer driver from within Device Manager.
You may have to reconnect the printer to do this, not sure!
Make sure, if you reconnect the printer, that you disconnect
it before you reboot or it will find a driver for it again.
Then, if its still in programes & features, try uninstalling it
again.
Won't hurt to try.
regards
CL
J
Hey!! Thanks alot I finally got rid of that old printer. I was about to start
pulling my hair out. Thanks for your time and info.
"LoneWolf" wrote:
> Hi jcf
> again.
> Won't hurt to try.
> regards
> CL
