Unexpected Shutdown
L
I recently have had a rash of shurdowns when I leave my notebook on
overnight. I am curently running Windows Vista Home Premium on a Toshiga
notebook. WHen I leave it on overnight 60-70% of the time when I go to bring
it out of logoff I get the meaasage "Windows have recovered from any
unexpected shutdown, windows will notify when a solution is available". Has
anybody else had this problem an if so, any solutions?
Thanks in Advance
Larry
davidjchuang
Power User
Thanks in Advance
Larry
Yes I had that a few times, but on different situations.( I left my laptop on sleep mode.) It did not happen during logon, and it was random. I had the same message too. Anyway, no apparent damage had been done, so I just "forget about it ". Sorry I have no solution for you. Just to tell you that you're not alone on this .
B
Assuming you mean "bring it out of sleep" when you say "bring it out of
logoff".
How to Troubleshoot a Vista Sleep Mode Problem and Find a Solution
http://www.vistax64.com/tutorials/63567-power-options-sleep-mode-problems.html
*Report back, please*
"LAR" <LARHOME@xxxxxx> wrote in message
news:67133C43-D18B-4C13-87F2-BF1DC71CF1DE@xxxxxx
>bring it out of logoff I get the meaasage "Windows have recovered from any
> Thanks in Advance
> Larry
C
Christopher Stott
Re: So far no solution offered ---so, I'll ask again
I have silverlight installed and have not noticed any changes at all. But if
i wanted to uninstall it, it's listed under my installed updates with all
the rest. I even have a patch for crysis in there. Its wierd that you can't
see any optional updates because I think I've installed 3 or 4 optionals and
they are all there with the rest. Is there some setting that you may have
changed? I know I'm not much help, sorry.
"davidjchuang" <davidjchuang.37heb0@xxxxxx-mx.forums.net> wrote in message
news:davidjchuang.37heb0@xxxxxx-mx.forums.net...
> Joe;674745 Wrote:
>> > davidjchuang;674607 Wrote:
>> > Fair enough. Try this : - Miscrosoft Silverlight 1.0 ( kB 946609)
>> > Optional Published 2/26/08. Hypothetically I installed that in early
>> > March, and in April I found out I didn't want it after all. It's too
>> > far
>> > back for system restore. Now what? Besides ,system restore should not
>> > be
>> > one of the options. There HAS to be a direct way to uninstall. Don't
>> > you
>> > think so ?? Thank you.> >
>> David,
>> I couldn't find a direct way to uninstall Silverlight. I guess
>> Microsoft wants you to keep it installed. I did find a program that
>> might help. Here's the link: 'Perfect Uninstaller - A Better and
>> Easier Uninstaller' (http://www.perfectuninstaller.com/index.php)
>> Claims to be able to uninstall programs that are not uninstallable.
>> Let us know if that works for you.
> Thank you very much for you time researching my question. As I said
> earlier, it was a hypothetical scenario. But it is not far-fetched to
> find oneself installing something one doesn't want later on, i.e. that
> Silverlight was really intrusive, I was glad I found that out early
> enough to remove it via system restore.What REALLY bothers me is that MS
> allows us to uninstall the "auto" updates, but not the optionals ???
> What's the deal? I'll keep that link for future ref. Thanks again.
> David JC Huang
> davidjchuang
davidjchuang
Power User
> David JC Huang
> davidjchuang
Weird is right. There ARE others asking the same question as mine. We can't find them in " installed updates " file.Would you tell me what's your computer's configuration?
Speaking of weird, your response showws up in " Unexpected shutdown " instead of "So far no solution offered ---". This is the 3rd time that happened to me.
Anyway, thank you.
B
Control Panel>Programs and Features>View Installed Updates should show you
ALL installed updates.
"davidjchuang" <davidjchuang.37gyc1@xxxxxx-mx.forums.net> wrote in message
news:davidjchuang.37gyc1@xxxxxx-mx.forums.net...
> .Joe;674508 Wrote:
>> > davidjchuang;674444 Wrote:
>> > Forgive me if I re-post the same question, but I really need to know.
>> > If
>> > I installed an OPTIONAL update from windows updates, and I wanted it
>> > out. How do I uninstall it. Those OPTIONAL updates DO NOT show up in
>> > the
>> > Installed Updates file, nor do they show up in the Programs & Features
>> > folder, so there is no way to click and uninstall. Last time I had to
>> > do
>> > a system restore to get rid of the Silverlight. But, if I had one
>> > installed a while back, system restore would be out of the question.
>> > So,
>> > what's next ? Thank you.> >
>> David,
>> Not sure that it can be uninstalled, but I'll look around. What's the
>> number and name of the update you want to uninstall?
> Hi, Joe. Nice to "hear" from you again. There is no one particular
> update in mind. It's just that since it is not obvious to know the
> function of any optional update, I could have installed it by mistake,
> and if I didn't catch on early enough, I would need to know how to
> correct the mistake. It is unacceptable that I can uninstall
> automatically installed updates, and yet I could do nothing on the
> optionals. That's my beef. Thank you.
> davidjchuang
I have the solution for these unexpected shut downs. At least for the ones who leave them on for more than 20 minutes without doing anything with it. You need to click start menu, then control panel, after that you click on system and maintenance, and then power options. After that you click on change power plan settings of your current power plan. At put the computer asleep you say never. Now here comes the important part.. you click on change advanced power settings, and you click on hard disk, and on turn off hard disk after, you see that it says only 20 minutes, so you need set it for a much longer time, this will do the trick and will help unexpected shut downs.
