"Unidentified network", local but no internet connection.
S
Steve Arrants
Using Vista Ultimate. Just this past Sunday had networking problem start.
On starting Vista, there is no internet connectivity. Network and Sharing
Center shows two networks--Home and Unidentified Network. The only fix that
works is to disable the Unidentified Network , then go to Device Manager and
disable my network card. Then in the graphic of my Home computer and the
internet, click on the red X and go ahead with the Diagnose and Repair dialog
that displays. It tells me that my LAN card is disabled, do I want to enable
it? Click Yes, and it repairs. I can access the internet again.
I reset the cable modem and changed cables, but that didn't solve this
problem.
Does anyoen have any advice?
B
Barb Bowman
please post the text output of ipconfig /all from an elevated
command prompt.
On Tue, 28 Aug 2007 10:16:01 -0700, Steve Arrants
>problem.
Barb Bowman
MS Windows-MVP
http://www.microsoft.com/windowsxp/expertzone/meetexperts/bowman.mspx
http://blogs.digitalmediaphile.com/barb/
R
Robert L [MVP - Networking]
It could be the incompatible issue. This post may help,
Vista: unidentified networkThe Network and Sharing center will identify the network as "unidentified network", with limited connectivity. I've checked with motherboard and chipset ...
www.chicagotech.net/netforums/viewtopic.php?p=1377&sid=efd7bb2fe5c9d78c8fafa9d9fb0d00cc
Bob Lin, MS-MVP, MCSE & CNE
Networking, Internet, Routing, VPN Troubleshooting on http://www.ChicagoTech.net
How to Setup Windows, Network, VPN & Remote Access on http://www.HowToNetworking.com
"Steve Arrants" <SteveArrants@xxxxxx> wrote in message news:0ED75DD9-F25A-47AC-9B64-A93C9D968516@xxxxxx
problem.
S
Steve Arrants
I don't think it is motherboard or chip incompatibility. It was working fine
for months, and only started this behaviour after this weekend's WGA server
outage.
S
Steve Arrants
> command prompt.
Here is the result when the internect can't be connected:
Microsoft Windows [Version 6.0.6000]
Copyright (c) 2006 Microsoft Corporation. All rights reserved.
C:\Users\Steve>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : TheGoldenCompass
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : hsd1.vt.comcast.net.
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . : hsd1.vt.comcast.net.
Description . . . . . . . . . . . : Intel(R) PRO/100 VE Network Connection
Physical Address. . . . . . . . . : 00-11-2F-1E-82-21
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::a527:e053:155c:c344%9(Preferred)
IPv4 Address. . . . . . . . . . . : 75.68.170.77(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.248.0
Lease Obtained. . . . . . . . . . : Tuesday, August 28, 2007 5:53:18 PM
Lease Expires . . . . . . . . . . : Friday, August 31, 2007 11:14:54 PM
Default Gateway . . . . . . . . . : 0.0.0.0
75.68.168.1
DHCP Server . . . . . . . . . . . : 68.87.71.16
DHCPv6 IAID . . . . . . . . . . . : 117444911
DNS Servers . . . . . . . . . . . : 68.87.71.226
68.87.73.242
NetBIOS over Tcpip. . . . . . . . : Enabled
Tunnel adapter Local Area Connection*:
Description . . . . . . . . . . . : isatap.hsd1.vt.comcast.net.
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
fe80::200:5efe:75.68.170.77%10(Preferred)
68.87.73.242
NetBIOS over Tcpip. . . . . . . . : Disabled
Tunnel adapter Local Area Connection* 2:
Description . . . . . . . . . . . : Microsoft 6to4 Adapter
Temporary IPv6 Address. . . . . . : 2002:4b44:aa4d::4b44:aa4d(Preferred)
68.87.73.242
Tunnel adapter Local Area Connection* 9:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
Physical Address. . . . . . . . . : 02-00-54-55-4E-01
C:\Users\Steve>
And here is the result when I disable.enable the LAN card via Device Manager:
MMicrosoft Windows [Version 6.0.6000]
Lease Obtained. . . . . . . . . . : Tuesday, August 28, 2007 6:06:00 PM
Lease Expires . . . . . . . . . . : Friday, August 31, 2007 11:14:52 PM
Default Gateway . . . . . . . . . : 75.68.168.1
68.87.73.242
Description . . . . . . . . . . . : Microsoft ISATAP Adapter
68.87.73.242
Default Gateway . . . . . . . . . : 2002:c058:6301::c058:6301
68.87.73.242
C:\Users\Steve>
B
Barb Bowman
there is no default gateway in the "bad" state.
I wonder if
http://support.microsoft.com/default.aspx/kb/933872/en-us might
apply?
On Tue, 28 Aug 2007 15:18:00 -0700, Steve Arrants
>> command prompt.
> 75.68.168.1
> 68.87.73.242
> 68.87.73.242
> 68.87.73.242
>C:\Users\Steve>
> 68.87.73.242
> 68.87.73.242
> 68.87.73.242
>C:\Users\Steve>
Barb Bowman
MS Windows-MVP
B
Barb Bowman
#8
could you double check which you downloaded as there are 2 - one for
x86 and one for x64? also, please check control panel, programs and
see if this has already been applied.
On Wed, 29 Aug 2007 03:38:02 -0700, Steve Arrants
>I downloaded the update, but when I started it, Windows tells me that "This
>update does not apply to your system."
>> I wonder if
>> apply?
Barb Bowman
MS Windows-MVP
R
#9
As said this is the router/modem/NIC incompatible with the Vista. When the computer turn on IPv6 can't receive the default gateway which is 0.0.0.0 so that you can not access the Internet. However, afar repairing, the default gateway is setup to Default Gateway . . . . . . . .. . : 75.68.168.1. the solution could be as simple as sizable the IPv6.
"Steve Arrants" <SteveArrants@xxxxxx> wrote in message news:A1FEA5B3-5323-49F3-9766-A4DD57366345@xxxxxx
> command prompt.
75.68.168.1
68.87.73.242
68.87.73.242
68.87.73.242
C:\Users\Steve>
68.87.73.242
68.87.73.242
68.87.73.242
C:\Users\Steve>
S
Steve Arrants
#10
B
Barb Bowman
#11
try going into the adapter properties and unchecking IPv6
On Wed, 29 Aug 2007 09:38:03 -0700, Steve Arrants
>I downloaded the correct version; checking Control Panel, it seems that the
>update had already been applied.
>> Barb Bowman
>> MS Windows-MVP
Barb Bowman
MS Windows-MVP
