Unsucessful SP1 install-Help me PLZ!!!!
Has anyone else had this problem?
  • Total voters
    3
544
Location
Rhode Island
I got this:
    Dell
    Intel(R) Celeron(R) CPU 420 @1.60 GHz
    Dell Inspion 530 Default
    PNY 4GB 240-Pin SDRAM DDR2 800 (PC2 6400) Dual Channel
    ATI Radeon HD 2400 PRO
    Realtek HD Audio
    Gateway PnP Monitor
    1024x768 @ 75 Hz
    Seagate 250G ATA SATA-II
    Dell Inspiron 530
    None
    Logitech EX100 Combo
    100 MB/s
Thao
Teh Waiz Wun.
Power User
47
Location
BC, Canada
Error code 0x800F0826 is basically telling you that some other update(s) is failing, which is causing the Service Pack to fail. Can you install all available updates on Windows Update, reboot, then try the installer again?
If this problem persists, we will have to find out what Updates have failed and why.
Can you please do the following:
1. Open Windows Update by clicking the Start button, clicking All Programs, and then clicking Windows Update.
2. In the left pane, click View update history.
3. Find the updates that have failed to install, in the last week or two.
Finding out the updates that have failed can help us repair and reinstall those, which will allow the SP1 to install successfully.
    Gateway MT6821
    Intel® Core™ 2 Duo T5200
    Intel® 945GM
    2GB DDR2
    Intel® GMA 950
    SigmaTel 9250
    Built-In
    1200x800
    1.5 MB (Yes, slow high speed.)
544
Location
Rhode Island
Hey Thao,
Here is a clip:
    Dell
    Realtek HD Audio
    Gateway PnP Monitor
    1024x768 @ 75 Hz
    Dell Inspiron 530
    None
    100 MB/s
Barman58
Staff member
1,790
Location
Newport, South Wales, UK
  • Show second system?
    No
    Operating System
    Windows 10 Pro 1709 Fall Creators Update (16299.192)
    Asus M5A78L-M USB3
    32GB [4x8GB] DDR3 1600 MHz
    Asus nVidia GTX750TI-OC-2GD5 (2GB DDR5)
    2 x 1920x1080 @50Hz
    Internal
    Crucial CT256MX100SSD1 256GB SSD,
    WDC WD30EZRX-00D8PB0 3TB,
    Toshiba HDWD130 3TB
    Seagate ST2000DM001-1CH1 2TB,
    External (USB3)
    Seagate Backup+ Hub BK SCSI Disk 8TB
    2.5/3.5 Hot Swap Cradle, USB3 + eSata (client HDDs)
    NAS 4TB +1TB
    Wireless Logitec - MX Master + M570 Trackball
    Wireless Logitec MK710 + K400+
    37.8 MB Down 9.5 MB Up
544
Location
Rhode Island
barman58,
That is what i did last night and it worked fine at first, restarted my system a couple of times then said. Update failed. restoring settings.
Any other advice? i dont know what to do
    Dell
    Realtek HD Audio
    Gateway PnP Monitor
    1024x768 @ 75 Hz
    Dell Inspiron 530
    None
    100 MB/s
Barman58
Staff member
1,790
Location
Hi, Neverhavemoney
The original problems with installing SP1 was related to incompatible drivers there is a list here ...
Windows Vista Service Pack 1 is not available for installation from Windows Update and is not offered by Automatic Updates
If you have anything on the list you may want to check if there are newer drivers available at the relevant manufacturers website, download and install them then retry the SP1 install.
you could also try a System File Check just to confirm there are no corrupt files that may cause a problem.
System Files - SFC Command - Vista Forums
    No
    Operating System
    Asus M5A78L-M USB3
    2 x 1920x1080 @50Hz
    Internal
    Toshiba HDWD130 3TB
    External (USB3)
    NAS 4TB +1TB
544
Location
Rhode Island
Now what do i do?
    Dell
    Realtek HD Audio
    Gateway PnP Monitor
    1024x768 @ 75 Hz
    Dell Inspiron 530
    None
    100 MB/s
Barman58
Staff member
1,790
Location
#8
Hi Neverhavemoney,
ok that says that you have corrupted files (you probably worked that out yourself! ), at least it gives us somewhere to start looking
if you have a look at Shawn's tutorial, he gives a method to identify the corrupt files (section 1 in the tips) from the log files created by SFC
http://www.vistax64.com/tutorials/66978-system-files-sfc-command.html
once you have the details of the files you need you may want to check out this link
DLL-files.com - Download all your missing dll-files.
if you replace the bad files that will hopefully cure your problem
keep us informed
    No
    Operating System
    Asus M5A78L-M USB3
    2 x 1920x1080 @50Hz
    Internal
    Toshiba HDWD130 3TB
    External (USB3)
    NAS 4TB +1TB
544
Location
Rhode Island
#9
Hi Neverhavemoney,
keep us informed
Hey barman,
I went on dell.com and found this amazing tool. Its Dell™ PC Restore by Symantec™ (for Microsoft® Windows® XP) and Dell Factory Image Restore (for Microsoft® Windows Vista®) exist on a hidden partition on your hard drive that contains an exact copy of your computer's original setup. These programs allow you to reset your computer's operating system and software to the original state in which it was shipped to you from Dell.
It was awsome and i am gunna try installing SP1 tonight after i get all of my programs back up and running. Worked amazing so far!!!
Thanks,
Ben
    Dell
    Realtek HD Audio
    Gateway PnP Monitor
    1024x768 @ 75 Hz
    Dell Inspiron 530
    None
    100 MB/s
Barman58
Staff member
1,790
Location
#10
Hi ben,
Yes I'm aware of the recovery option on Dell and other machines from large manufacturers, I assume you had your files , documents, pictures etc, on another partition or backed up.
As your machine will have been reset to how it was when it left the factory you will have to install all the updates again that you did previously.
It may be worth installing SP1 and the other updates before you re-install any other programs
I would still advise installing SP1 from the downloaded file rather than via Windows Update just to be safe
Good luck and keep us informed of progress
    No
    Operating System
    Asus M5A78L-M USB3
    2 x 1920x1080 @50Hz
    Internal
    Toshiba HDWD130 3TB
    External (USB3)
    NAS 4TB +1TB
