Update installation cancelled
Bill Weaver
I get Hewlett Packard Updates on a routine basis. I have owned the computer for about 45 days and have received app 6 updates. They are:
HP Security Update
Realtek high definition audio driver update
Intel matrix storage manager driver update and
Windows help and support update
Each time I have tried to install them and each time I have received a note in the status column that "installation cancelled"?
Any ideas?
Thanks in advance.
Bill Weaver
mansrm81
Re: Default Programs - Program Default Associations
Try going to hp's website and manually download them and install them.
    HP Compaq Presario/SR5113WM
    AMD Athlon 64 X2 3600+ 1.9Ghz
    Asus M2N68-LA
    PNY Nvidia 8400 GS 256MB
    On board RealTek
    Acer X163W LCD
    1366x768
    7200 rpm
    Western Digital 160 GB IDE
    Dynex 400w
    Nothin Special
    Stock
    Wireless Logitech LX7
    Comcrap 10mb cable
twlykins
HP Security Update
Any ideas?
Thanks in advance.
Bill Weaver
TRY THIS:
Select Start
All Programs
Select HP
Right click HP Update
Select Properties
Select Compatibility tab
Check Run this program as administrator
Select Apply
Select Show settings for all users
Select Apply
Select OK
Select OK
The computer might need a restart at this point.
then:
Select Start
All Programs
Select HP
Select HP Update
Search for updates and install...
Tom
Thao
Teh Waiz Wun.
Power User
Personally, I would try using Windows Update, rather than the one that HP supplied. Windows Update knows your hardware (most of the time) and is often less bugged than 3rd party update software.
However, this is a matter of personal opinion. If you like the HP Update software, let's troubleshoot this.
    Gateway MT6821
    Intel® Core™ 2 Duo T5200
    Intel® 945GM
    2GB DDR2
    Intel® GMA 950
    SigmaTel 9250
    Built-In
    1200x800
    1.5 MB (Yes, slow high speed.)
micgel
I have the same problem with update.
Thanks Tom (twlykins), your solution Run this program as administrator
was the solution and update are now done..
zansu
I'm having the same problem with HP installations being canceled. I just recently purchased this laptop with Vista Home Premium x64, but I'm still used to XP. I haven't had the time to get all of the Vista tricks down.
I was following the steps recommended above, to change the Privilege Level so that the updater runs as Administrator, but the option is grayed out.
I am the only user on this computer and should have full administrative privileges, so I'm not sure why I wouldn't have that option. UAC has been disabled.
Anyone have any additional suggestions for a Vista noob?
I may stick with the Windows updates like some have suggested, but it bothers me that I don't have the ability to run something as administrator when I *am* the administrator.
Thanks!
Suzanne
micgel
Suzanne,
You can 'Run this program as an administrator'' with UAC enable or disable.
But for permanent change:
The checkbox to "Run this program as an administrator" under the Compatibility tab of an .exe's properties is always grayed out if UAC is disable.
Re-enabled UAC to have the option back.
Michel
zansu
Thanks!
So, I need to enable UAC, check the box to run that one .exe as administrator, then disable again (assuming I don't want all the other annoyances that come along with UAC)?
Wow... I knew UAC was supposed to be a pain when it's enabled, but I didn't realize I'd start running into problems if I disabled it.
Thanks again,
Suzanne
laurin1
I believe this statement is totally incorrect:
"Windows Update knows your hardware (most of the time) and is often less bugged than 3rd party update software."
I've actually had numerous bad experiences where MS drivers and software updates for hardware caused severe problems. Why would MS know how to create drivers better than the manufacturer of the product? They have less invested as well. I rarely ever install the drivers from MS update.
JimJoe
Thanks!
Thanks again,
Suzanne
I have UAC disabled for months now on my home computer. No problems.
    Acer Aspire X1700
    ASUS
    3 gigs
    EVGA 1 gig GeForce 210
    Vizio 21" tv
    1920x1080 resolution
    fans that came with it
    basic USB
    basic USB
Strafgod
This worked for me after months of frustration, thanks Tom!
I finally found this after being prompted to download the "installation cancelled fix" update and having the installation cancelled!:sarc:
Thank you Tom, you rock!!!
HP Security Update
Any ideas?
Thanks in advance.
Bill Weaver
TRY THIS:
Select Start
All Programs
Select HP
Select Properties
Select Apply
Select Apply
Select OK
Select OK
then:
Select Start
All Programs
Select HP
Select HP Update
Tom
Splaxx
Thanks guys... I just did a search for this issue because HP's 'Urgent; HP Update fix for "Install Cancelled issue" was not installing. LOL You guys fixed it, and HP missed the boat I guess.
Thanks Again.
Joshes
The 'Run as Admin' totally worked. Thanks! Yes HP tech support sucks!
Cheers
    Intel Quad Q9550 - 2.83GHZ
    EVGA nForce 780I SLi
    Patriot Extreme Viper 4GB
    XFX GeForce 9800GTX SLi
    Samsung SyncMaster T220
    2x Western Digital Caviar SE16 250GB SATA2 7200RPM 16MB 8.9MS Hard Drive
    Corsair HX1000w
    Antec Twelve Hundred
    Scythe Ninja Plus REV.B Heatpipe Fanless Heatsink
    Logitech Mx518
    Microsoft Reclusa
veta67
When I got to the Hp Update window, I only have a settings button, not a properties button. If I hit "next" it starts to download updates.
Veta
veta67
Got it! Thanks Tom. Forgot to right click. Reread it when I was awake, instead of tired out, and it made sense. After months of no installation, it works!
Veta
