updates fail to load error
speedy1gon
5
i keep getting fail error messages after it reboots can't load updates these are them Cumulative Update for Media Center for Windows Vista (KB974306)
Installation date: ‎11/‎7/‎2009 9:12 AM
Installation status: Failed
Error details: Code 80073712
Update type: Recommended
Install this update to resolve issues with Media Center for Windows Vista. For a complete listing of the issues that are included in this cumulative update, see Microsoft Knowledge Base article 974306. After you install this item, you may have to restart your computer.
More information:
October 2009 Cumulative Update for Media Center for Windows Vista
Help and Support:
Microsoft Support
Update for Internet Explorer 8 for Windows Vista (KB976749)
Installation date: ‎11/‎6/‎2009 3:03 PM
Error details: Code 8007041D
Update type: Important
Install this update to resolve issues that may occur after installing the Internet Explorer cumulative security update issued as MS09-054
(http://www.microsoft.com/technet/security/bulletin/ms09-054.mspx). After you install this item, you may have to restart your computer.
More information:
An update is available for Internet Explorer that resolves issues that occur after you apply security update 974455 (MS09-054)
Help and Support:
Microsoft Support
Microsoft .NET Framework 2.0 Service Pack 2 Security Update for Windows Vista Service Pack 2 and Windows Server 2008 Service Pack 2 (KB974470)
Installation date: ‎11/‎6/‎2009 3:02 PM
A security issue has been identified that could allow an unauthenticated remote attacker to compromise your system and gain control over it. You can help protect your system by installing this update from Microsoft. After you install this update, you may have to restart your system.
More information:
MS09-061: Description of the security update for the Microsoft .NET Framework 2.0 Service Pack 2 on Windows Vista Service Pack 2 and Windows Server 2008 Service Pack 2: October 13, 2009
Help and Support:
Microsoft Support
More information:
Help and Support:
Microsoft Support
help please
Flavius
Expelled
2,049
This error code addressed to damaged C:\Windows\Servicing and C:\Windows\WinSxS folders and registry keys
solutions:
1.Fill missing files & keys -worth only to try if damages are not too big -I have to diagnose it is worth to do or not.
2.Repair installation
follow to below:
1.Run cmd.exe with administrative previlliges (right click on cmd.exe) as admin and type:
sfc /scannow
When it finish type in cmd.exe
findstr /c:"[SR]" %windir%\logs\cbs\cbs.log >%userprofile%\Desktop\sfcdetails.txt
on your desktop appear sfcdetails.txt
2.Try reregister WU How do I reset Windows Update components?
3.Run Readiness Tool Description of the System Update Readiness Tool for Windows Vista, for Windows Server 2008, and for Windows 7
This tool even don't help create CheckSur.log file in C:\Windows\Logs\CBS\CheckSUR.log
4.Download firegenul Altair Technologies Ltd.
place firegenul.exe in C:\Windows\System32
next again run cmd.exe with admin previlliges and type:
firegenul
it creates report from WindowsUpdate.log and is stored in C:\Windows\System32 as FireGenReport.htm
FireGenReport.htm,CheckSur.log,sfcdetails.txt pack and attache to post
speedy1gon
5
i went thru all steps still no fix i get thru upto stage 3 update then it reverts back error not configure correctly i dont know how to get checksur.log get error message in update page of code 80073712 if it helps
Flavius
Expelled
2,049
Of course all steps couldn't at once fix your issue.I have to analyze logs,then I try fill missing files & keys manually.Under posting area is attachments manager.The best way pack all files to *.zip and use attachments meanger to upload it.(Image below attached)
Flavius
Expelled
2,049
The tool report about corrupted these keys:
HKEY_LOCAL_MACHINE\REM_SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_bthmtpenum.inf_31bf3856ad364e35_0.0.0.0_none_23d1b875dc1c1425]
"Microsoft-Windows-WPD7IP-SKU-Package~31bf3856ad364e35~x86~~7.0.6002.18112.bthmtpenum.inf"="6.0.6002.18112@128"
[HKEY_LOCAL_MACHINE\REM_SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_wpdfs.inf_31bf3856ad364e35_0.0.0.0_none_49c6cb2f1ac5fe37]
"Microsoft-Windows-WPD7IP-SKU-Package~31bf3856ad364e35~x86~~7.0.6002.18112.wpdfs.inf"="6.0.6002.18112@128"
[HKEY_LOCAL_MACHINE\REM_SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_wpdmtp.inf_31bf3856ad364e35_0.0.0.0_none_43743b50cedad977]
"Microsoft-Windows-WPD7IP-SKU-Package~31bf3856ad364e35~x86~~7.0.6002.18112.wpdmtp.inf"="6.0.6002.18112@128"
[HKEY_LOCAL_MACHINE\REM_SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_wpdmtphw.inf_31bf3856ad364e35_0.0.0.0_none_1c1880257795310c]
"Microsoft-Windows-WPD7IP-SKU-Package~31bf3856ad364e35~x86~~7.0.6002.18112.wpdmtphw.inf"="6.0.6002.18112@128"
file
C:\WindowsWinSxS\Manifests\msil_ehepg_31bf3856ad364e35_6.0.6002.22215_none_de0d807fe52ff24b.manifest
and folder
C:\Windows\WinSxS\msil_ehepg_31bf3856ad364e35_6.0.6002.22215_none_de0d807fe52ff24b
To these objects Administrators don't have full control,fighting with permissions is sophisticated here,thus I suggest fix it from Vista DVD level to workarround permissions
1.Download attached to post FixPacks.zip file -in zip file is packed Packs folder -you have to unpack it and place directly on C: exactly as I show below:
2.Boot Vista DVD (if you don't have Vista DVD instead use special recovery disk http://www.vistax64.com/tutorials/141820-create-recovery-disc.html )
Choose language>>Repair Computer>>WinRE>>command prompt
and type:
robocopy C:\Packs C:\ /E /IS
reg load HKLM\REM_SOFTWARE C:\Windows\System32\config\Software
reg import C:\Packs\Fix.reg
del C:\Windows\Logs\CBS\CheckSur.log
next boot into system and try install hotfixes again,if it again fail again run Readiness Tool and attache new CheckSur.log file
speedy1gon
5
i ran thru packs with vista dvd then i try to in stall updates but with same failure
so i ran thru test again and try to install readiness tool it would extract but no updates it stay same for long time with no update files below again
Flavius
Expelled
2,049
#8
You should at once show sfcdetails.txt log -as you can see yourself from this file there are many damages also in C:\Windows folder -Readiness Tool can't detect damages in whole C:\Windows -it can only detect issues in C:\Windows\Servicing and in C:\Windows\WinSxS folders.In your situation like yours Readiness Tool even not working correctly it can't detect or recogonise all problems.There is no worth to fill missing files and keys otherwise you have to exchange manually half your system :sleepy: .
The best solution for you is Repair Install using Vista DVD SP2 or upgrade to Windows 7
if you don't have Vista DVD SP2 there are two methods to get it:
METHOD I
exchange Vista DVD How to replace Microsoft software or hardware, order service packs and product upgrades, and replace product manuals
it will cost about 20$
METHOD II
Prepare yourself sleapstreamed Vista SP2 Sliptream Vista SP2
You can also decide upgrade to Windows 7
Upgrade Install with Windows 7 - Windows 7 Forums
maybe another solution is use System Restore http://www.vistax64.com/tutorials/76256-system-restore-undo.html
Of course it only help if you have correct checkpoint
5
#9
first of all thank you for all help i went bought new hard drive reinstalled vista
still loading up some updates an software but i think for the best we did give it a shot for repair but proven for me to be tooo. much
time i really would like to devote somewere else
im planning to get new puter soon i will try windows 7 maybe will do me better:D
