Solved USB Device Not Recognized (iPod)
144
Location
Crystal Lake, Illinois
Every time I plug in my iPod I get this at the bottom right...
When I close out of that I also get this in the middle of my screen...
I have restarted my computer and tried different USB ports. Nothing shows up in "Computer" about a removable device. Please help me out.
Sean
    Intel Core 2 Quad Q6600
    Gigabyte GA-EP45-UD3P
    Corsair XMS2 Xtreme Performance 2x2GB DDR2
    GeForce 9800 GTX+
    19'' Samsung 1440 x 900 (2ms) SyncMaster Widescreen Flat Panel
    OCC Gamestream 600w
    Apevia X-Discovery
    Razer DeathAdder
    Razer Lycosa
    Comcast; Download: 21.08Mb/s | Upload: 4.27Mb/s
1,337
Did the ipod have any instructions in the manual on how to install drivers?
    Sony Vaio Z46GDU
    P9700@2.8GHz w/6MB L2 cache 1066MHz FSB
    6GB DDR3 1066MHz SDRAM
    13.1" WXGA True Colour Tough
    1600x900
    320GB SATA 7200RPM
    1MB/s
144
Location
The drivers just come with iTunes. (I have the latest version)
See this is what happened. I am pretty sure this is why it is messed up but I can't be sure.
I deleted one of my partitions on my HD. This is where iTunes was installed so I reinstalled it to get it working correctly. I then added all my music back to my library and now tried to finally plug in my iPod and this all pops up..
    GeForce 9800 GTX+
    OCC Gamestream 600w
    Apevia X-Discovery
    Razer DeathAdder
    Razer Lycosa
1,337
Ahh. Can you insert the ipod with itunes on? So open Itunes, then try inserting the device.
    Sony Vaio Z46GDU
    1600x900
    320GB SATA 7200RPM
    1MB/s
144
Location
It is still doing the same thing. The iPod won't even show in "My Computer" so therefore it won't show up in iTunes.
    GeForce 9800 GTX+
    OCC Gamestream 600w
    Apevia X-Discovery
    Razer DeathAdder
    Razer Lycosa
1,337
Is this a laptop or desktop? Can you try a different USB port? If that doesn't work, can you check if the ipod works on another pc?
    Sony Vaio Z46GDU
    1600x900
    320GB SATA 7200RPM
    1MB/s
1,337
    Sony Vaio Z46GDU
    1600x900
    320GB SATA 7200RPM
    1MB/s
144
Location
#8
Desktop; I tried all different ports (some straight into the Motherboard and some on the front of my case). All of the USB ports do the same thing. I can check tomorrow to see if it works on my brothers computer.
I went into device manager and this is what it shows for my iPod... (the one highlighted)
Just thought this might help solve the problem quicker.
    GeForce 9800 GTX+
    OCC Gamestream 600w
    Apevia X-Discovery
    Razer DeathAdder
    Razer Lycosa
1,337
#9
Hmmm. Check the links above too, delete the unknown device and reboot. The usb's on the front are connected to the front panel header but if they don't work, try another pc and the links I posted previously. This is probably why a cheap USB mp3 player is the best.:p
    Sony Vaio Z46GDU
    1600x900
    320GB SATA 7200RPM
    1MB/s
144
Location
#10
Eh, I haven't actually had many problems with my iPod. I personally love it though, had it for about two years. I am going to bed right now but I will get back to you tomorrow about all of this. I checked the links though and I have already done most of it.
Sean
    GeForce 9800 GTX+
    OCC Gamestream 600w
    Apevia X-Discovery
    Razer DeathAdder
    Razer Lycosa
144
Location
#11
Actually I just unplugged my iPod from the computer. It was froze on the "Do not disconnect." screen with the 'Red Cross' thing. I held the 'Menu Button' and the 'Center Button' to reset it. I plugged it back in and now it is working. Thanks for your help though :p
Sean
    GeForce 9800 GTX+
    OCC Gamestream 600w
    Apevia X-Discovery
    Razer DeathAdder
    Razer Lycosa
1,337
#12
You should wait for a device to disconnect although my patience occasionally ignores this. Mark this thread solved - click on the exclamation mark.
    Sony Vaio Z46GDU
    1600x900
    320GB SATA 7200RPM
    1MB/s
144
Location
#13
Yeah I sent in the solved thing. I would have waited except for that it was frozen and I knew that because the 'Red Cross' wasn't "blinking."
    GeForce 9800 GTX+
    OCC Gamestream 600w
    Apevia X-Discovery
    Razer DeathAdder
    Razer Lycosa
1
#14
Here's what worked for me, when I had similar issue. fought it for a long while...
unplug your ipod, and shut down iTunes. Navigate to the folder your music is stored in. (i.e. c:\users\<username>\Music\iTunes). there should be a file there called "sentinel" (you may have to show hidden files and folders to see it). Move it out of that folder or delete it. Open up iTunes. It should recreate that file. Then plug in your iPod. Your PC should then recognize it.
good luck
