Usb flash drive removal
I
Ian
When I safely remove my USB flash drive, the light does not go out.
If I remove the drive with the light on - the drive needs to be checked when
inserted next
I have to go into Device Manager and reset the root of the hub. It still
takes a minute for the light to go off. It works fine if I wait for the
light to go off.
Is there a patch or KB update to fix this?
C
Carey Frisch [MVP]
Reliability update for the USB stack in Windows Vista
http://support.microsoft.com/?kbid=925528
Carey Frisch
Microsoft MVP
Windows - Shell/User
inserted next
light to go off.
I
Ian
I'm sorry,
I already have this update.
My search on Technet located it.
It did help a little, the device resets quicker.
Last time I tried this the flash drive turned off a litle bit after I opened
Device Manager.
Thanks,
Ian Kester-Haney
> Carey Frisch
> Microsoft MVP
> inserted next
> light to go off.
