USB support
R
Ron Miller
I have Virtual PC installed on Windows 7, but I have no need of XP
mode. Instead, I installed Windows 98 SE because I have a Win 98 app
that controls my speakers, and it was never upgraded to run on NT-
based systems. I installed Virtual PC because on the "Features" page
of the MS's Virtual PC Web site, it prominently claims "USB support."
However, my app will not even install because it says the system has
no USB support. Indeed, in the Win-98 Device Manager, there is no USB
entry.
So, is there truly no support for USB in Virtual PC? If so, how can
it be enabled in a Win 98 SE virtual machine?
Thanks for any clues.
Roon
R
Robert Comer
Yes and no.
USB is supported through the use of the Windows VPC Integration Components,
but Win98 isn't one of the OS's that can run the integration components.
(You need WinXPSP3 and above)
Bob Comer <Microsoft MVP - Virtual Machine>
"Ron Miller" <[email protected]> wrote in message
news:[email protected]
> entry.
> Roon
R
Ron Miller
On May 6, 9:54 pm, "Robert Comer" <[email protected]>
> Yes and no.
> > entry.
> > Roon- Hide quoted text -
> - Show quoted text -
Foiled again!!
Thanks for the kind explanation.
Next question, then, would be: Is there ANY virtualization software
that might be able to give USB support to a virtual Win 98 SE ?
Ron
R
Robert Comer
> Foiled again!!
My motto. Computers can sure be frustrating, can't they. :/
VMWare Player (free), or VMWare Workstation should do it, but I haven't
actually used USB in a Win98 VM under either, but they do USB quite
differently from Windows Virtual PC.
Bob Comer
>> Yes and no.
>> Components,
>> > entry.
> Foiled again!!
> Ron
P
Poutnik
In article <[email protected]>, bobcomer-removeme-
@mindspring.com says...
> > Foiled again!!
VirtualBox by Sun/Oracle http://www.virtualbox.org/
support USB to guest systems too,
but as it was said I have never tried it with Win98 guest OS.
Poutnik
The best depends on how the best is defined.
B
Bill Grant
"Poutnik" <[email protected]> wrote in message
>> > Foiled again!!
> Poutnik
The key here is Win98. USB was still pretty new in 1998.
P
Poutnik
[email protected] says...
> > Poutnik
I know, I had Win98SE,
and it was always very surprised by any USB device,
driver always needed.
Poutnik
R
Ron Miller
> > > Foiled again!!
> Poutnik
I've tried both VMWare Player and VirtualBox before without success,
but I haven't done it for a while. I'd given up until I got Windows 7
and saw the blurb about USB support being added to Virtual PC. I'll
try the latest version of VirtualBox again and report back here.
If only these Altec Lansing speakers weren't so darned good. I've had
them for 12 years, and I still love them. I actually have control
over everything but balance and adjustment of the virtual center
channel on Dolby ProLogic. Having that functionality is worth giving
up a small amount of HD space to install virtual Windows 98 SE, but
the applet that controls the speakers does it via USB, so the virtual
machine has to run Win 98 with USB support. I'm not the only one
clinging to these old speakers as evidenced by the fact that control
of the ACS 495 speakers is still on the top ten FAQ list at
AltecLansing.com.
Thanks.
Ron
