usb2ide driver for Vista
A
Aaron Gray
Does anyone know of a USB2IDE driver for Vista. Both XP and Win98 had one
but Vista does not seem to have one availiable.
Many thanks in advance,
Aaron
B
Bob F.
"Aaron Gray" <ang.usenet@xxxxxx> wrote in message
news:6306dsF252hbkU1@xxxxxx
> Aaron
I've put a number of IDE drives in trays or boxes that connected via USB and
they all came up with the native Vista USB and HD drivers. If it's a new
drive to your system you might need to use the disk mount utility that comes
with the drive. What are you trying to do exactly? and what's not working?
BobF.
A
Aaron Gray
"Bob F." <bob@xxxxxx> wrote in message
news:18098529-0A4B-4DBB-BF47-2BCF40F8C1F4@xxxxxx
>> Aaron
> and they all came up with the native Vista USB and HD drivers. If it's a
> new drive to your system you might need to use the disk mount utility that
> comes with the drive. What are you trying to do exactly? and what's not
> working?
I have a USB drive that requires the usb2ide driver usb2ide.inf and
usb2ide.sys this is availiable on XP and Win98 but is not on Vista, I cannot
seem to find a usb2ide driver for Vista anywhere on the net.
Thanks,
Aaron
B
Bob F.
news:630a6pF25nu56U1@xxxxxx
>>> one but Vista does not seem to have one availiable.
>>> Aaron
>> that comes with the drive. What are you trying to do exactly? and
>> what's not working?
> cannot seem to find a usb2ide driver for Vista anywhere on the net.
> Thanks,
> Aaron
Are these requirements from some documentation you have or did an attempt at
installing this drive tell you it needed them? Did you try to install the
drive? Many of the drivers are already in Vista...but maybe not the same
name...or they are universal.
BobF.
D
David H. Lipman
| Thanks,
| Aaron
You should not need any special driver. It such Plu 'n Play.
If it doesn't contact the manufacturer/vendor of the un-named unit.
Dave
http://www.claymania.com/removal-trojan-adware.html
Multi-AV - http://www.pctipp.ch/downloads/dl/35905.asp
A
Aaron Gray
news:%23PEGeUJfIHA.4880@xxxxxx
>>>> Aaron
>>> a new drive to your system you might need to use the disk mount utility
>>> what's not working?
>> Thanks,
>> Aaron
> at installing this drive tell you it needed them? Did you try to install
> the drive? Many of the drivers are already in Vista...but maybe not the
> same name...or they are universal.
Vista is asking for a driver called USB2IDE and failing to find it. The
drive software does not provide a Vista driver so it is probably a dead
parrot on Vista.
Aaron
B
Bob F.
news:630d85F25jafgU1@xxxxxx
>>>>> Aaron
>>>> USB and they all came up with the native Vista USB and HD drivers. If
>>>> it's a new drive to your system you might need to use the disk mount
>>>> utility that comes with the drive. What are you trying to do exactly?
>>> Thanks,
>>> Aaron
> parrot on Vista.
> Aaron
Hmm, doesn't look good. When Vista searches for new drivers, make sure the
option is used to search the internet for it rather then look only locally.
BobF.
J
John Barnes
#8
Your boxes have a BIOS built in to handle the conversion
>> Aaron
> working?
> BobF.
A
Aaron Gray
#9
"John Barnes" <jbarnes@xxxxxx> wrote in message
news:ejYJKyJfIHA.4684@xxxxxx
Yeah ? But you still prsumably need a USB2IDE driver to broker the
connection.
Aaron
>>> Aaron
>> what's not working?
>> BobF.
A
Aaron Gray
#10
news:E9923E27-1025-4BFB-91FD-F5FAA2593B06@xxxxxx
>>>>>> Aaron
>>>> Thanks,
>>>> Aaron
>>> attempt at installing this drive tell you it needed them? Did you try
>>> to install the drive? Many of the drivers are already in Vista...but
>>> maybe not the same name...or they are universal.
>> parrot on Vista.
>> Aaron
> the option is used to search the internet for it rather then look only
> locally.
Yes, its tried the internet. You are right it does not look good. I have a
couple of the devices too.
Aaron
B
Bob F.
#11
news:630q7aF247smhU1@xxxxxx
>>>>>>> had one but Vista does not seem to have one availiable.
>>>>>>> Aaron
>>>>>> If it's a new drive to your system you might need to use the disk
>>>>>> mount utility that comes with the drive. What are you trying to do
>>>>> Thanks,
>>>>> Aaron
>>> parrot on Vista.
>>> Aaron
>> locally.
> Aaron
What are these devices BTW. I'm not trying to be nosey but have you tried
competitive products that may use similar Vista drivers as a work around.
BobF.
